Scoring of new rotors and pads - Defender Source
Old July 14th, 2011, 11:10 AM
I just replaced my rotors and pads and after just over 1000 miles (mostly highway and all on-road) I already have scoring on the rotor. I haven't had a chance to pull the pad yet but does anyone have any thoughts on why this is happening? I checked the hub temps and this hub is slightly warm so it could be dragging a bit, but wouldn't the wear still be even given the pads and rotor are both new if it was?
Originally Posted by pendy
I'm here for the D's
Old July 14th, 2011, 11:50 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
brands ?
- Charles Eames
Old July 14th, 2011, 12:05 PM
Ferodo pads, and not sure offhand on the rotors - what's in the AB kit.
Old July 14th, 2011, 12:21 PM
metallic pads will do that
Old July 14th, 2011, 02:16 PM
Seems normal.
Old July 14th, 2011, 02:26 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Thats way normal look to them. Have they been squealing?
Old July 15th, 2011, 10:22 AM
No squealing. There is a distinct groove forming though - that's what I don't expect and find dissapointing. I'll take a closer look when I get home.
Old July 15th, 2011, 11:25 AM
airbornrover
William Skidmore
SIII 109 SW
Only thing I can think of is some grit/dirt got in there and is scoring but I wouldnt worry about it.
Old July 15th, 2011, 12:26 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Looks like you got a "soft" pebble stuck in there which wouldn't cause a noise. Pull'em and check to see if you got junk in there. Check all the brakes while you're down there. The rest of the glazing pattern looks normal except for the groove you got started.
Old July 15th, 2011, 01:00 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Rotor scoring or galling is pretty common these days because the quality of rotors is not as good as in the past. When you couple that with a really good metallic pad, scoring is the result. Getting a cooler rotor via slotting or cross drilling can help eliminate the problem.
pads
new rotors and pads... anything else? hutch Defender Technical Discussions 19 November 25th, 2009 10:51 AM
ForSale DBA Gold Defender 90 front rotors and Genuine pads nosivad_bor For Sale - Parts 1 August 22nd, 2009 01:11 PM
Defender Rotors, pads, lines, surrey and other items hobbesz For Sale - Parts 10 May 1st, 2007 09:55 PM
D90 rotors, pads artm Defender Technical Discussions 12 April 12th, 2007 01:19 PM
110 Rear w/ABS Rotors and pads brn24whl For Sale - Parts 0 April 2nd, 2007 09:09 AM
