School me on wolf wheels.... - Defender Source
Old May 21st, 2015, 11:40 PM
There are a couple out there and I don't know enough about them...
RN has a 6.5 heavy duty and a proline
What is correct and why does it matter since they are all steel wheels...
I'm 1/2 way thinking I should just go dakars or blimbo if the price is basically the same (and the wheel weight)
I'm going to pull the boosts and bfg at's and go MT's for my next tire
95' D90 - daily driver..
Old May 21st, 2015, 11:42 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Whatever you decide just make sure the studs and nuts are properly matched.
Old May 21st, 2015, 11:44 PM
rovertrader's Avatar
rovertrader
Dale
Alloys- break/crack
Steel- bend, and can be beat back into shape
Proline- half the weight/strength of Wolfs
RN HD- Zack will have to comment
Wolf- gold standard, XHD, never heard of a failure.
Old May 21st, 2015, 11:45 PM
tjfslaughter
thomas
Burbon
Originally Posted by rovertrader View Post
Alloys- break/crack Steel- bend, and can be beat back into shape Proline- half the weight/strength of Wolfs RN HD- Zack will have to comment Wolf- gold standard, XHD, never heard of a failure.
I think the issue with Wolfs is some people think they can run them without the extended studs.
Old May 22nd, 2015, 12:09 AM
Tire is going to be BFG Km2's or the new cooper pros (if there is a size that matches) I'd like to go skinny on the tires.. Prefer a 33" in 255mm if possible
Use is more trail than road (I'm keeping the boosts and KO's for that)
How about weight of say the Dakar vs the 110 wheels any specs ?
I'd like to keep weight if possible down since the truck is getting a bit portly and I'm running the stock 3.9, and wheels are unspung mass.
So the RN wheels are not as durable?. All of them?
Custom steel (ala lucky8) same deal ?
Good commits and keep them coming
Old May 22nd, 2015, 12:59 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Robert swing by the shop next week before your Uwharrie trip, I have a set of Wolfs with km2's you can use for the weekend to see how you like them.
Old May 22nd, 2015, 02:03 AM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
I have KM2s on Wolfs and like it. What size tires?
Old May 22nd, 2015, 06:02 AM
rovertrader
Dale
As Jeff states above, the NAS110 wheel is also a good choice. But remember, D130s come stock with Wolfs, d/t their inherent strength.
As far as the truck weight, all the more important to have a strong wheel- kind of a chicken/egg issue...
Old May 22nd, 2015, 07:27 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I've got a set of *real* Wolfs and a set of Allmakes or whatever(probably same as Proline?)...
I dont think the aftermarket Wolfs are half the weight; and should easily do what a steel wheel needs to do...
Rent my
Old May 22nd, 2015, 07:31 AM
Jim-ME
Jim Ecker
1964 Series 2/2a bitsa
If the Proline "Wolf" from RN wheels are 1/2 the weight I'd hate to think what it would be like to try to lift 235s with real Wolf wheels.
Jim
Old May 22nd, 2015, 12:16 PM
Let the record show that Im in favor of ditching the Boosts. It really depends on the intended tire and use of the truck. For steel I prefer the ANR1534 (NAS110 wheel) but if you are running narower tires the basic 5.5 arnt bad either. -Jeff
Aren't these for tube tires only?
Old May 22nd, 2015, 12:20 PM
I'm pretty sure Zack compared the genuine and aftermarket Wolf wheels and said they are indentical in appearance and sizing.
Old May 22nd, 2015, 12:27 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Robert, lets get a WOLF group buy. Thats 10! Make it happen Zack.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old May 22nd, 2015, 12:31 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Thank you Red, that is correct. I think the weight difference was less than a pound IIRC. There's a thread on here with the info somewhere.
Old May 22nd, 2015, 12:48 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Just shot these on the shipping scale. .15lb difference, Proline being lighter
Old May 22nd, 2015, 01:06 PM
Here, I believe: http://www.defendersource.com/forum/...tml#post591494
Old May 22nd, 2015, 01:08 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Saw that...thought I had posted photos too.
Old May 22nd, 2015, 01:34 PM
byrnecc's Avatar
byrnecc
Conor
1986 ex-mod 110
You can you just need to up the torque, per the MOD
AESP 2320-D-122-811 MODIFICATION INSTRUCTION No. 36:-
INTRODUCTION
1
1.1 The decision has been made to carry out a campaign change of the DEFENDER wheel rim to the DEFENDER(HS)WOLF wheel rim, in complete vehicle sets (qty 5).
1.2 The DEFENDER used a tubeless (7.50x16) tyre fitted with an inner tube on a tubed type rim. The tyres currently in use on the vehicle can be changed over to the new tubless rim utilising a 'snap-in' rubber valve. Due to the heavier construction of the replacement rim, the wheel nut torque has been increased to 170 Nm (125lb ft) to compensate for this.
Replacement wheel brace to be demanded and placed with CES to cope with increased wheel torque. Securing the wheel nuts as described is technically safe and road legal, even though the wheel stud does not protrude all the way through the nut.
Old May 22nd, 2015, 02:56 PM
So the weight delta is .15 lb.. Pretty much equal.. I assume no difference in construction between the 2 as well (both are welded steel wheels after all)
Both are going to be a malleable steel. Both 6.5x16 tubeless
Am I missing anything here ?
Seems like with wolfs you get 1 less thread engaged (and should use open steel lug nuts which I was going to anyway)
Missing anything here?
I'm in for a group buy.. of black ones (5)
Old May 22nd, 2015, 03:28 PM
Yah, no problem with the stock studs and wolf wheels.
Wheels Wheels Wheels disco dog Misc. Chit-Chat 22 December 3rd, 2009 04:13 PM
Driving School 1of40 Defender Technical Discussions 3 July 18th, 2006 03:17 PM
Factory sponsored school looking for driving instructors - Northern Vermont 2007 solihul Misc. Chit-Chat 0 March 11th, 2006 10:30 PM
aviation school flippedrover Misc. Chit-Chat 13 October 11th, 2005 04:08 PM
LR Driving School in Canada OCD90 Misc. Chit-Chat 8 October 5th, 2004 10:21 PM
