School me on Heater core removal - Defender Source
Old February 24th, 2007, 09:03 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I am taking out my heater core, hasn't worked in years anyway. Anything I need to know? Any pointers? Thanks!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 25th, 2007, 12:09 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Hey David,
First... take the hood off.
Remove heater hoses, and cables (don't loose the little green clips!!)
Then fastners on the wing, and remove the ducting to the heater. Go to the passenger foot well and remove the bolts that that secure the heater braket (easier with another hand).
You should be able to remove the entire heater. Take it to the bench and drill out all the rivits holding the top and bottom on. The heater core should then just fall out. you may take thie oppertunity to check the blower motor for function and clean it of dirt.
NOTE: Either be gentle with the foam that seals the core or use some weather striping to replace it around the core itself as well as the junction of the heater box and bulkhead.
Now just and rivit away and put the whole thing back togather.
It is really quite easy.... by far the easiest heater core I have ever done on any auto.
Feel free to ask any questions... but I'm sure you will find it easy.
Old February 25th, 2007, 07:50 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Don't order a replacement from AB. It's a Britpart and the inlet/outlet hose connections are too close together-makes it very difficult to get the hoses on. Also, it's not a drop in fit and required some cutting of the heater box to make it fit.
Best to go genuine on this one.
Old February 25th, 2007, 09:16 AM
artm
Arthur Maravelis
97 SW
I also drilled three holes in the low point where the blower is attached for water drainage.
Old February 25th, 2007, 11:07 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Rebuildable
Can you recore the heater core?
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old February 25th, 2007, 12:44 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by D90user
Hey David,
Thanks a lot! Sounds reletively easy. I am not replacing it, I am just pulling it all out and maybe building some storage where it used to be. No point in really having it as I don't have doors or a roof. Can I just cut the coolant hose and loop it back to the motor?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 25th, 2007, 12:55 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Yeah thats what I do in my trail truck.
JP
legend in my own mind
Old February 25th, 2007, 01:04 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey Pendy,
You want a 24 volt heater core motor. I bet thats a big seller for you! I'll give you a smoken deal on it too!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 25th, 2007, 06:02 PM
D90user's Avatar
D90user
steve
Yep. I had my heater bypassed that way for a while.
You shoud run that hot coolant to another tank to heat veggie oil. That would be one bad ass beast running on grease!!!
Old February 25th, 2007, 08:08 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I was trying to think of some use for the heat, not coming up with much. I like to support Big Oil as much possible. Foreign Big Oil is even better.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 14th, 2009, 03:39 PM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
For those of you who have replaced the heater core, where did you buy an OEM heater core?
Old January 14th, 2009, 04:06 PM
Then you don't want to remove the core. Pull the whole heater unit and intake duct and throw them away.
Don't you even need defogging? Even when I lived in tropical Australia I used the heater on occasion.....
Old January 15th, 2009, 08:04 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I believe RN sells the core. But not sure if it is proline or not.
Old January 15th, 2009, 10:37 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
AB is in the process of bringing the Genuine cores in.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old January 15th, 2009, 11:45 AM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
Thanks, Eric, David. Just called RN and it's definitely genuine. Steve, thanks for posting the how-to.
javier
Old September 14th, 2009, 01:23 AM
jvelador's Avatar
jvelador
Javier Velador
'95 D90 / '66 IIA
Bought genuine at Rovers North but hadn't had a chance to replace it until today. It wasn't as bad as I thought it would be. Followed the steps mentioned here
http://www.defendersource.com/forum/...ad.php?t=19520
And this attachment
http://www.defendersource.com/forum/...chmentid=18522
There were no rivets to remove on my '94's heater box.
Just little black screws that hold two plates at the top and bottom of the heater core. These two sets of plates hold the core in place.
Just saved myself 2-3 hours of somebody's shop rate.
Old September 14th, 2009, 11:05 AM
Anyone got a complete LHD heater assembly they want to sell to me?
Old September 14th, 2009, 03:19 PM
http://www.roversnorth.com/store/p-7...der-90110.aspx
http://www.roversnorth.com/store/p-1...off-90110.aspx
Old September 14th, 2009, 03:46 PM
Just called. No more New Take offs and the genuine one is out of stock for another month.
Old September 14th, 2009, 05:53 PM
you won't need heat until november anyway
heater
NAS D110 Heater Core Removal Jon_Winningham Defender Technical Discussions 6 January 8th, 2014 11:23 PM
WTB/WTT: for 87 RR heater core headdamage Wanted 2 November 17th, 2005 06:14 PM
Heater core ?? & FYI D90user Defender Technical Discussions 4 October 14th, 2005 03:27 PM
Heater core Burke Wanted 1 December 9th, 2004 12:21 AM
Easy heater removal ??? artm Defender Technical Discussions 1 October 10th, 2003 08:27 AM
