Scary Moment - Defender Source
Old July 26th, 2008, 01:29 AM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
Scary Moment
Had a brown trouser moment on the way home from work today. When I pushed in the clutch to change up to 4th gear, the engine started to over rev and was scream like a banshee. I immediately let the clutch back out and got on the brakes. Getting desperate I tried to blip the throttle and noticed there was no resistance on the peddle. The friggin accelerator cable had stuck open. I kicked at the peddle and couple times and it released its self, thankfully.
I pulled over and had a good look at everything and it all appeared normal. The rest of the drive home was VERY slow. Once home I pulled the cable and found it was binding up in the sheath. I have cleaned and lubed the cable and it seems to be working well now, but I think I had best get a new one ordered. Rovers North only lists a RHD one that I could find. I suspect that would be too short for a LHD truck.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old July 26th, 2008, 01:35 AM
George at RDS probably has one. I'd be surprised if he doesn't.
I guess your problem is with the cable in the sheath, but also it seems like the plastic barrel adjuster can come unseated and cause the throttle to not close. I had that happen on one of the v8 trucks, but the adjuster is the same on my 300Tdi.
coolant - which to use scoloco Defender Technical Discussions 37 May 2nd, 2009 04:24 AM
BSROA - D-90 Kodak moment... pmd Trips, Trails and Events 11 June 26th, 2007 03:31 PM
