satellite radio antenna install - Defender Source
Old November 22nd, 2004, 07:41 PM
nykx
nick
1995 black #2456. 1994 yellow #922
hey gang...im installing a surius tuner in my truck and am wondering if anyone has done this... if so - where to put the darn antenna?!?
Old November 22nd, 2004, 08:03 PM
Try this thread.
http://www.defendersource.com/forum/...ighlight=radio
Old November 22nd, 2004, 11:10 PM
Treuwer's Avatar
Treuwer
Trae Reuwer
94 D90
I have the XM roady2 in my truck, and it comes with a magnetic antenna. I ended up sticking it on the front bumper, darn aluminum, it still gets pretty good reception.
Old November 23rd, 2004, 07:01 AM
jimg
Jim Garaventi
97 ST
Installed my XM antenna under wing vent (see thread Dave posted). Easy, clean and works great.
Old November 23rd, 2004, 08:17 AM
ronward's Avatar
ronward
Redsrover
None - sadly
I have the Sirius FM modulator unit mounted on my dash. I ran the fiber optic antenna cable out the passenger side door along the top of the windshield in my soft top and stuck the magnetic end to one of the light taps on the roll bar. Perfect reception and the thing is stuck solid.
Old November 24th, 2004, 10:33 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
I have a navigation antenna that is similar situation, I too mounted it under the plastic wing vent on the driver side. Very good reception under there. If it's magnetic you may need to come up with a modified mount since it won't stick to the aluminum.
Old November 24th, 2004, 04:21 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Mine stuck pretty well to the little light mount tabs on the rollcage, though the roof rack blocked reception. It's since been zip-tied to the roof-rack.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 27th, 2004, 02:54 PM
nykx
nick
thx for all the suggestions! i ended up putting under the wing vent on the drivers side...installation was very quick and ez and the reception has been very good thus far!!
Old November 29th, 2004, 10:49 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Am installing same in the coming weeks. Please post should anyone experience difficulty with the under vent mounting.
Thanks!
radio
1997 Radio Antenna Removal ronward Defender Technical Discussions 12 August 8th, 2007 08:21 PM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
Dash install of radio paulb Defender Technical Discussions 3 December 17th, 2004 05:42 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
