Sankey trailer and wheel spacer? - Defender Source
Old December 20th, 2014, 11:24 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
I fitted 235/85/16 on my sankey narrow (early type) and when loaded one tire touche on bilt head on the side of the frame. My tire has now a rounded strip off. I know they are suppose to wear 6,50x16 narrower tire but, in 235/85/16 I have no need to carry a spare as my 110 has the same shoes.
I'm leaning on the wheel spacer to get rid of my troubles. Are the one from paddock strong enough?
Old December 20th, 2014, 12:24 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I use them on the 130 and on the Sankey wide track. No probs so far.
Kurt
Old December 20th, 2014, 12:37 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
Kurt, as a sankey owner, you know they take about 1 ton. Is this too much for spacer? Do you often load yours like I do mine?
Old December 20th, 2014, 01:06 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Jeff, this is less than the axle load on my 130!
No worries about these spacers. They are priceless and do what they are designed for.
Old December 20th, 2014, 02:41 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
Thanks.. Do you konw if I can use the same spacer as the 110? The metal "hubcap" will fit?
Old December 21st, 2014, 04:41 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Hmm, I'm not sure because I cut the extended part of the original caps off.
It might be to get in trouble with this.
But I'm not sure.
Old December 21st, 2014, 07:15 PM
Sort of hijacking this thread, but can you run 7.5x16 XZLs on a Sankey with no spacer without an issue?
Old December 21st, 2014, 09:22 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
You can if its a MKIII. This model Sankey came with 7.50 x16 tires on it.
Old December 21st, 2014, 10:06 PM
I have 235's on mine which is a 60's Mark II. It sounds like the issue is your wheel offset. I have the wolf/nato/130 wheels on mine, no rubbing
1974 Rapier Missile Supply Trailer :: 1974 Sankey Rapier Missile Supply Trailer FV241 kraison Defender & Series Truck Registry 1 September 4th, 2014 02:45 PM
2004 Disco and matching Sankey Trailer Gibson04 For Sale - Vehicles 10 September 6th, 2012 11:53 AM
1995 D-90 and 1964 Sankey Trailer jjstahl3 For Sale - Vehicles 30 October 20th, 2011 02:12 PM
1" wheel spacer - borrow Jase Defender Technical Discussions 0 July 16th, 2005 05:23 PM
255/85 wheel spacer experience D90user Defender Technical Discussions 6 July 13th, 2005 11:12 PM
