Sand Blasting, good or bad? - Defender Source
Old May 19th, 2015, 11:19 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Both the interior (behind the door panel) and exterior of the rear door on my D110 has some surface rust and some paint bubbling, enough to warrant a repaint.
The nooks and crannies on the inside have me concerned about not being able to completely eradicate the rust, so I am considering having the door sandblasted completely down to bare aluminum.
Is this a good or bad idea, especially that it's aluminum we're talking about, which tends to be softer than steel. What are the pitfalls if any? What do you recommend?
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old May 19th, 2015, 11:22 AM
You can't sand blast aluminum. It will warp from the heat.
You need to soda blast. You really need, though, to remove the aluminum skin and properly paint the frame first and then make sure it is isolated from the skin, to do things properly.
Old May 19th, 2015, 11:34 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Yeah. What Red said.
Black Rhino Lives Matter
Old May 19th, 2015, 11:35 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
John,
Thanks for the quick reply. Removing the aluminum skin require "opening up" the folds in order to separate the frame from the panel, correct? That's a little bit more "involved" than I had anticipated. Mind you I am not trying to cut corners, I want this done right.
What about having the paint stripped instead of soda blasting? Will this do the trick? What do you mean by: make sure it is isolated from the skin?
Thank you - Samer
2003 Discovery II
Old May 19th, 2015, 11:47 AM
You can strip. Soda blasting is the easiest. Soda blast and repaint is the simplest.
The aluminum and steel can't touch. If they do, then you get galvanic corrosion and the aluminum disappears.
Old May 19th, 2015, 12:25 PM
61rover's Avatar
61rover
John Crouse
Removing the skin (and reinstalling) is not a big deal. It's worhwhile as then you can sand blast the frame and even galvanize if you wish. I think it took me 10 minutes to remove the skin and it came off undamaged. Replacement skins are also available if yours is too corroded.
Old May 19th, 2015, 12:39 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
John,
Thanks for the reply. Just so that I'm clear and because this would be my 1st time doing this, removing the skin entails undoing the folds at the perimeter of the door, and separating the 2 halves from each other. Correct?
Any special tool for that? Any pointers you can provide would be greatly appreciated.
Thank you - Samer
2003 Discovery II
Old May 19th, 2015, 12:53 PM
61rover's Avatar
61rover
John Crouse
You are correct. I used a big screwdriver, but I'm sure there is something better. A wider tool would have made the job easier. Just work your way across the folds.
The skin is in two pieces. Remove the top piece first as it overlaps the lower piece slightly. Take your time as the skins are pretty thin and dent\deform easily.
To reinstall, I used a wooden block and a hammer to press the folds back down.
I just checked some of the usual suspects and couldn't find skin pieces available. If anyone knows a source, that would be great.
Old May 19th, 2015, 01:08 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Thank you John, exactly the information I was looking for.
Thank you - Samer
2003 Discovery II
Old May 21st, 2015, 01:10 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
For those of you who have undertaken a similar refurbishing/freshening of the rear door, while I have the door apart, are there any recommended upgrades you would recommend, such as to the hardware, hinges, washer pump, wiring, sound deadening, etc...?
Thank you - Samer
2003 Discovery II
Old May 21st, 2015, 01:32 PM
Galvanize the steel.
Old May 22nd, 2015, 01:15 AM
JASEcrest
Jason
'88 Defender 110
Saner: will you photo-document your project? I'm planning this route in a few months and have similar questions that you posted.
I did find a website when I was researching it a few months ago.
http://www.landyworld.co.uk/defender...er-door-frame/
Old May 22nd, 2015, 01:32 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Jason, will do. I already have some pics before disassembly. I will start a separate thread.
Thank you - Samer
2003 Discovery II
Old May 22nd, 2015, 02:01 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Here's a link to the new thread: http://www.defendersource.com/forum/...ore-62411.html
Thank you - Samer
2003 Discovery II
Fair price for sand blasting? JimC and evilfij need help asap evilfij Misc. Chit-Chat 18 April 1st, 2009 02:15 PM
sand blasting and powder coating in colorado... TravelerBT Defender Technical Discussions 2 January 14th, 2009 06:32 PM
Sand Blasting / Acid Dipping a Bulkhead J.5 Defender Technical Discussions 0 March 19th, 2008 04:07 PM
Soda blasting ... Retrofit Defender Technical Discussions 3 May 29th, 2007 06:20 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
