Salsibury rear disc brake conversion merged threadfest - Defender Source
Old August 25th, 2008, 11:28 AM
Talking I have rear disc brakes now!!
Woohoo! I did the rear drum to disc brake conversion this weekend, using all land rover parts, and am very excited about the outcome. Thank to Keith at Rovertracks for all his guidance.
There is no instructions on this, as it requires a mix of Defender 90, Disco I and RRC parts, so if anyone has questions, you can refer to Keith or I if your interested.
Few top roadblocks/lessons learned:
1) not all Type 37 bearings are the same. I bought a full set of replacement bearings from NAPA, to replace what I had as generally preventive measure, and not a single one of them would fit on my rear spindles, despite the fact that they had the same ID as the US made Timkens that were already in there (which would comfortably slide on and off the spindles). I will never buy anything but Land Rover and/or Timken bearings again.
2) Make sure I have all the parts up front, to include bolts. I had forgotten to order the bolts that mount the rotors to the hub. Those bolts, as well as the member to hub bolts are all hardened grade 10 quality M10 x 1.50. With the first axle completely apart, I had to run all over the place to find an equivalent. Home Depot, Lowes, Ace Hardware and NAPA don't stock M10 x 1.50 in grade 10 equivalent. I had to use grade 8 temporarily to get by. Don't be me.
3) Get a tap and die for M10 x 1.50 and keep it as part of the standard tool kit. Just about every bolt/nut/thread on the salisbury is that size/thread combo. I was installing a used RRC hub (varies from the 110 hub in that it has the threaded holes for the rotor) and the drive member holes were crudded. I ended up overtorqueing a bolt and snapping it off. What a PITA that was. After hours of attempting to drill out the bolt remains (and breaking multiple drill bits in process), I gave up. Running 4 bolts and tracking down a new hub. I quickly bought a metric tap and die set that night. Next morning taped and the holes on the other hub to clean them up and freshen the threads, and did the same to all the drive member bolts. Went together like a charm.
New brake system works great. My drum pads clunked because they were so worn, and now my brakes are nice, tight and quiet. I love that the new calipers have the drop in pads, making the next change quick and easy.
Thanks Keith! You da man.
Old August 25th, 2008, 11:41 AM
Can you refresh our collective memories on the parts list?
I have been meaning to pony up the $150 for the brackets, but am too lazy. I think I have everything else (new DI pads and rotors and non-abs RRC hubs).
Old August 25th, 2008, 12:57 PM
I'm wanting to do it also. I've already got the calipers, but need everything else. Did you use the caliper brackets that needed to be milled off a bit?
Old August 25th, 2008, 01:10 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Please post a step by step guide with pictures for all of us pitiful folks with drum brakes on the rear.
I have a few sets of non-ABS hubs JimC you can peruse on your shopping trip.
Ron
Old August 25th, 2008, 02:14 PM
this would be an awesome how to for the smaller projests section below.
Old August 25th, 2008, 02:20 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
I will post up some pics too as I pirated Kieth's list and directions. My project has been sitting for about a month and a half with one side half done and no time to finish.
You didn't answer the million dollar question though...does it stop a heck of a lot better?
Old August 25th, 2008, 03:04 PM
The brackets are the only part that needs to be modified. They have to be milled per Keith. It was my intention to do a build thread, and I was going to take pictures of the right side (after I had the learning curve down from the left side), but the broken bolt set me back a few hours out of my alotted project time, so I had to scramble to get it done.
Now that I know what the hell I'm doing, when I get my replacement hub, and tear down the left side again, I'll post pics and note instructions on that rebuild. I still have the old drum parts to illustrate with.
As for stopping power, I didn't do it for additional stopping power. I learned long ago when researching this, per ECR in a dated thread on the subject, that a disc conversion in the rear won't improve stopping power; only vented discs up front will do that (another conversion down the road, but much easier). And to be honest, when the drum pads are new and adjusted right, that's all the stopping power for me. I did this conversion because the drums suck at maintenance, and when they are wet/muddy. Disc are so much easier to maintain.
The pads are only a day old, so still setting in. Maybe I'll see a slight improvement after 100 miles or so.
Old August 25th, 2008, 03:07 PM
I'd also be happy to do a write up if you don't get around to it. I need to pull the axle for a refurb anyway.
Old August 25th, 2008, 03:40 PM
landrovered
S. Smith
I am not looking for shorter stopping I just want to get rid of the drum adjustment and have a consistant pedal.
Old August 25th, 2008, 04:22 PM
Then this conversion is for you!
Here is the quicklist of parts needed from Keith, plus all the implied. I'll have to get part#'s later.
REAR:
  1. 2x Caliper brackets (FTC 3306) and have them machined .100" on the caliper mounting side
  2. 2x Non ABS RRC hubs front or rear (they are same) The only difference with 93' 110 hubs is the thread holes for the rotor to mount to
  3. 2x Rear RRC/D1 rotors (non-vented)
  4. Disco/D90 Calipers
  5. Disco/D90 rear pads
  6. 4x caliper bolts from a Disco or D90(hardware store grade 10.9 is fine).
  7. Full seal set (or for wet hubs, just the double lip Inner hub seal:rtc3511
  8. Brake kit for rotors with 4x split pins and 4x anti-rattle springs
  9. 10x rotor mounting bolts
  10. left and right 110 rear disc brake stone shields (they mount right to the bracket)
  11. 4x M8 (I believe) nuts with washer and lock washer to mount stone shields to bracket
  12. 2x spindle lock washer (same as what you have already on the 93')
Things you can keep from the original drum/hub assembly
  1. Drive members
  2. Inner and outer race and bearings (if they are in good condition, just drift them out and install in new hub)
  3. Drive member bolts
  4. inner axle spacer
  5. axle retaining c-clip
  6. stub axle mounting bolts (2 each side are reinstalled with their nyloc nuts, and the other 4 each side mount directly through the stub flange into the caliper bracket.
Make sure to flip-off your drums when you pull them off. I got great satisfaction out of that.
Old August 25th, 2008, 04:30 PM
Does keith stock the brackets already machined? I should call and order a set.
Ron
Old August 25th, 2008, 04:37 PM
Ron - I think I can get them machined for you. PM me.
Old August 25th, 2008, 06:18 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
I already did the front vented conversion and still have a long pedal stroke and mushy feel (brakes have been bled recently). My hope was that the rear shoes were worn and way out of adjustment, that does seem to be the case. If this doesn't sort things out I'll start further investigation.
Old August 25th, 2008, 06:26 PM
I have a pulsating pedal that feels very non-confidence inspiring. I found a badly rusted brake line and hoped that would fix it. It didn't. Maybe I'll find another bad line, but I really just want to do this for the heck of it, especially since I've got the calipers just sitting around.
Old August 25th, 2008, 09:26 PM
Johnathan,
After my first day driving, I found my pedal stroke extremely short, very little pressure needed for full stop. The whole system feels very "tight' for lack of a better word. Before that, I had a long stroke with a clunk from the slack in my drums.
Jim,
as for you pulsation, I just replaced my wife's disco's rotors and pads, as a pulsation can only mean one thing..a warped rotor. After I swapped them out, problem gone.
Old August 25th, 2008, 09:28 PM
Brand new rotors - less than 150 miles on them...
Old August 25th, 2008, 09:57 PM
maybe your drums are warped then?
Old August 25th, 2008, 10:02 PM
I should replace them with discs!
Old August 25th, 2008, 10:22 PM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
Just a thought but at the shop I used to work at, we had more than several brand new rotors that where warped out of the box, it may be worth going down and having them turned as they are new and little materal would need to be removed, unless they are really bad. But as soon as they go on the machine they will be able to tell you how bad they are out.
brake, conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
Caliper brackets for a rear Salisbury disc brake conversion Tyler Wirken Wanted 0 September 22nd, 2009 12:17 PM
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
