Salsibury rear disc brake conversion merged threadfest - Page 8 - Defender Source
Old March 27th, 2016, 03:21 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Why are you fitting mud shields when most take them off?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 27th, 2016, 04:19 PM
I'm not planning on installing them. The list is a cut and paste.
Old March 27th, 2016, 05:29 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
This is the route I went when converting mine to disc. I already had a set of hubs everything else was purchased new.
http://forums.lr4x4.com/index.php?showtopic=11685
Ryan
84 110SW County LHD
07 L322 Vogue
Old March 27th, 2016, 06:27 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Dave, I had FRC8540 for the stub axle, which is the original drum brake stub axle. I think the difference is discussed further up the thread.
Old May 31st, 2016, 12:21 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Half Shaft Problem
I did this conversion in March while rebuilding my 86 110. I just now got to the point where I have the truck almost ready to drive and went to install the half shafts but they are too short?? Any ideas?? I tried the stock drive members and the heavy duty ones.
Here are the parts I used for the conversion:
  1. 2x Caliper brackets (FTC 3306) and have them machined .100" on the caliper mounting side
  2. 2x Non ABS hubs for 88-90 RRC front or rear (they are same) The only difference with 93' 110 hubs is the thread holes for the rotor to mount to. (FRC6139)
  3. 2x Rear RRC/D1 rotors (non-vented)
  4. Post 1994 Disco Calipers and rotors
  5. Disco rear pads
  6. Brake kit for rotors with 4x split pins and 4x anti-rattle springs
  7. 10x rotor mounting bolts
ID:	150604   Click image for larger version
ID:	150606   Click image for larger version
ID:	150608   Click image for larger version
Old May 31st, 2016, 01:04 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I found out that the axle shafts on a Salisbury are different lengths depending on whether they were for a factory disc brake or drum brake setup. Which do you have?
Old May 31st, 2016, 01:09 PM
There are two ways to do the conversion. One using pre-ABS RRC hubs which uses the drum brake length shafts, the other using factory disc sals parts which uses the disc brake length shafts. On the plus side, sals disc length shafts are (were) dirt cheap. Like 20-25ukp a side.
Old May 31st, 2016, 01:10 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
IIRC the difference in length is 3/4" between the earlier and the later style axle shafts
Old May 31st, 2016, 01:14 PM
86Defend110
Jesse
My truck had factory drum brakes. Does this mean I need to buy longer half shafts?
Old May 31st, 2016, 01:16 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I think so. I bought them from lucky8. Good prices
86Defend110
Jesse
These are the hubs I used:
I am not sure how the half shafts ended up being too short?
------ Follow up post added May 31st, 2016 10:17 AM ------
Ok, any chance you have the part numbers still?
I want to make sure I get the right ones!
Thanks much.
Old May 31st, 2016, 01:20 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Drum
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Disc
Old May 31st, 2016, 01:37 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Not sure if this helps, but here's what I used:
FTC942 or RUB101740 HUBS (RRC 92-94) Hubs (I had a set)
FTC1725 HALF SHAFT LH
FTC1726 HALF SHAFT RH
FTC1740 STUB AXLE (2)
FTC3145 OIL SEALS (2)
RUC105200 DRIVE MEMBER (2)
RTC3129 WHEEL BEARING (4)
FTC3185 BEARING SPACER (2)
FTC3179 STUB NUTS (4)
FTC943 PLASTIC HUB CAP (2)
FTC2783 HUB OIL SEAL (2)
FTC3306 CALIPER BRACKET
STC1268 CALIPER RH
STC1269 CALIPER LH
FTC3846 ROTORS
DA4185 EBC BRAKE PADS
Bolts right up, no machining of the ftc3306...
Old June 2nd, 2016, 03:21 PM
86Defend110
Jesse
It turns out I already have the longest half shafts made so there is not an option to buy longer ones, only a shorter set for later axles.
I must have the wrong combo of Hubs, stub axles, rotors that make my stock half shafts too short...
Old June 2nd, 2016, 03:27 PM
Are you sure? What makes you think they are too short? How much engagement into the diff splines are you getting? AFAIK, there is no way to set things up longer than stock.
Old June 2nd, 2016, 03:56 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
You need to refit the drum braked stub axles... the front "disc braked" stubs don't fit onto the salisbury casing very well for a start, and they're too long... as you've just discovered.
Old June 2nd, 2016, 04:00 PM
86Defend110
Jesse
Using the stock drive members the half shafts don't engage the diff at all...
------ Follow up post added June 2nd, 2016 01:01 PM ------
Ok thank you much. I still have the stock ones I will swap those over this weekend.
Old June 2nd, 2016, 04:08 PM
See post 87...
Originally Posted by Wolf Fabrication View Post
Okay, here we go again. I am embarking on the rear disc conversion now. There has been a little back and forth between Keith and I on the proper parts for my truck. The confusion lies in what hub should go with what stub/spindle. To clear this up, Keith tells me:
"There are three types of factory stubs on Salisbury rear ends.
Really early type 83-85ish work with pre 1993 front hubs only for disc brakes. You have these stubs, I have these hubs.
Early type 86-93ish these work with RRC hubs front or rear (long non abs pattern usually pre 1991) you have these hubs but not the stubs.
Late model 1994 to current. These use Disco 1 hubs. If you have these you already have disc brakes."
Thus for me to keep my stubs, I need early 90 front disc hubs. If I want to use RRC hubs, I need to source Salisbury rear stubs from 1986-1993.
Old December 28th, 2016, 04:20 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Bump
brake, conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
Caliper brackets for a rear Salisbury disc brake conversion Tyler Wirken Wanted 0 September 22nd, 2009 12:17 PM
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
