Salsibury rear disc brake conversion merged threadfest - Page 3 - Defender Source
Old June 30th, 2009, 06:26 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Just to confirm that the hubs I should get for this are P/N FTC860, I noticed Paddocks has some for 20GBP each and I have some other things to order from them this week as well so figured I might as well start putting parts on the shelf.
Old July 1st, 2009, 07:30 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I'm not sure if these will work... I used the earlier hubs, FRC6139 on mine.
Those later ones are the thinner type as per 300Tdi/Td5 (and early 200Tdi, which is where the FTC860 comes from)
Old September 14th, 2009, 09:39 PM
I'm finally getting around to posting pix from my conversion. I followed the same formula as outlined by Overlander at the beginning of this thread and I owe big thanks to Keith at Rover Tracks for masterminding this set-up and being the source of the machined caliper mounting brackets.
Cost for this wasn't too great all things considered:
Caliper brackets - under 200, machined
Calipers - free from my stash
New rotors and pads - 150-ish
4 Timken Set 37 wheel bearings - 60
RRC non-abs hubs - free in trade from Evil Ron
Even if you don't have a stash of some of the correct parts, this conversion shouldn't cost more than 1000 bucks, maybe slightly over if you bought all new OEM hubs etc.
Anyway, I'll let the pix speak for themselves. This isn't a step-by-step, but should allow you to get a good visual of how everything comes apart and bolts up.
Name:	DSCF3734 - Resized.jpg
ID:	21492   Click image for larger version
Name:	DSCF3733 - Resized.jpg
Name:	DSCF3722 - Resized.jpg
ID:	21494   Click image for larger version
Name:	DSCF3726 - Resized.jpg
Name:	DSCF3730 - Resized.jpg
ID:	21496   Click image for larger version
Name:	DSCF3731 - Resized.jpg
Name:	DSCF4197 - Resized.jpg
ID:	21498   Click image for larger version
Name:	DSCF4200 - Resized.jpg
Name:	DSCF4201 - Resized.jpg
ID:	21500   Click image for larger version
Name:	DSCF4203 - Resized.jpg
Name:	DSCF4204 - Resized.jpg
ID:	21502   Click image for larger version
Name:	DSCF4210 - Resized.jpg
Name:	DSCF4214 - Resized.jpg
Old October 22nd, 2009, 04:00 PM
Salsibury disc conversion questions
Can I buy the newer shafts and use ABS hubs and not machine my brackets?
Ron
Old October 22nd, 2009, 04:09 PM
Salisbury ABS hubs ? Normal hubs don't fit salisbury shafts- @ least doesn't look like they would.
Old October 22nd, 2009, 05:48 PM
RN has the abs style salisbury shafts on sale, I was thinking of buying them and using whatever hubs go with them and not machining the brackets.
Old October 22nd, 2009, 09:01 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
You will need the hubs, stubs, axles and caliper brackets. Of course rotors and caliper too.
Disco hubs are the same and the rotors and calipers from that same Disco should line up.
Keith
Big, Red and ... aaa Red..
Old October 22nd, 2009, 11:14 PM
ok, so I can bolt all the stuff from a disco I onto the end of the axle (with brackets) and then buy new shafts from an ABS truck? Are the axles on the ABS one the "thin" flange?
Old December 31st, 2009, 06:03 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Will the rear hubs from a D90 work for this conversion? Previous posts seem to indicate using RRC hubs. I have a 90 axle that I want to rob the parts from...
Old January 20th, 2010, 12:23 PM
Just an FYI if you use the RRC hubs - early RRC non-abs hubs have 3/8-18 drive flange bolts and the M10 1.5s will not work. I stumbled upon this discrepancy and Keith squared me away. If that piece of info is in this thread, I keep not seeing it when I read it over.
Old February 9th, 2010, 04:34 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I am glad I found this. This is definitely a wise upgrade for the 130.
Old July 1st, 2010, 08:18 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I may have skimmed over it, but I'm confused on whether the orignal axle shafts can be re-used.
Semper Fi!
Old July 1st, 2010, 08:59 AM
No change in my axle shafts or drive hub when I did this.
Old July 1st, 2010, 09:10 AM
Wolf Fabrication
Sterling Archer
'08 D3
Awesome, thanks! Looks like I have all the parts except the caliper brackets.
Semper Fi!
Old December 18th, 2010, 09:07 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Will I need to get new Stub Axles to do this conversion on a 1983 110, with a Salisbury?
Old December 18th, 2010, 11:36 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Only 83's and early 84's have a different stub axle which has the bearing diameter all the way to the thread for the hub nuts, if your stubs have about a 3/8-1/2" unthreaded step just past the hub nut threads (towards the middle of the car) you're in good shape. If you don't have the step a set of front pre 1994 hubs are a direct fit but rather rare. Unless you put Disco hubs and stubs on the front to accomidate upgraded CV's and axles, then you can use the takeoffs.
Keith
Old December 18th, 2010, 12:22 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thats great,
Old December 18th, 2010, 05:00 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
So if i pull my 1985 90 axle, (disco axle) swap I can use the stub off of that?
Old December 18th, 2010, 06:05 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Nope, the Salisbury stubs pilot on teh outside diameter of the flange on the axle, Rovertypes aside from very early RRC's pilot on the inside diameter.
Keith
Old December 19th, 2010, 08:02 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
What year and type stub axles should I look for? (If mine are no good, which is likely)
HRC1924
Does anyone know what hubs this part number is?
brake, conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
Caliper brackets for a rear Salisbury disc brake conversion Tyler Wirken Wanted 0 September 22nd, 2009 12:17 PM
Rear disc brake options kellymoe Defender Technical Discussions 44 April 9th, 2008 09:34 AM
