Salsibury dics brake rear end - Defender Source
Old March 19th, 2013, 09:21 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I was just wondering about the lucky few that got a rear end with disc brakes form David. What else has to be done when one of these gets installed in a truck that had a drum brakes?
Old March 19th, 2013, 09:52 PM
unbolt drive shaft, unbolt flex brake line from old axle,unbolt trailing arms from axle, unbolt the plate that hold the balljoint to the top of the axle, swap the axles, bolt trailing arms on, bolt plate down on new axle, re-attach driveshaft, bleed blakes. Done
Key to this is to unbolt the plate that holds the rear ball joint. These are known for being mothers and removing them almost always fooks the rubber boot. By simply unbolting the plate, Bobs your Uncle.
Old March 19th, 2013, 09:59 PM
solarguy's Avatar
solarguy
Abraham Bell
So no proportioning valve differences or anything like that?
Old March 19th, 2013, 10:00 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Good to know that the brake lines are a simple re-attach. I was hoping I wouldn't have to deal with Classic Tube, etc.
nope- just brakes that don't need adjusting
Old March 19th, 2013, 10:12 PM
solarguy's Avatar
solarguy
Abraham Bell
Doesn't sound too bad. What's the difference between disc versa drum in the strength department?
Old March 19th, 2013, 10:19 PM
same housing,diff,shafts are slightly different but not much. I have used drum brake shafts in disc brake axles while waiting for a new replacement. Its pretty easy to convert a drum setup over to discs. There's a couple write ups on here.
Old March 19th, 2013, 11:06 PM
The proportioning is different, but no one seems to care.
brake, rear end
Salsibury rear disc brake conversion merged threadfest Overlander Defender Technical Discussions 159 December 28th, 2016 04:20 PM
$200,000 blr 130!!!!!!!!!! rijosho The Flea Market 39 July 25th, 2012 09:58 PM
Parking Brake and Rear brake light gas-man Defender Technical Discussions 9 February 20th, 2012 11:40 AM
Blew u-joint in rear, help on 4 bolts removal on brake drum UpnOver Defender Technical Discussions 3 February 2nd, 2012 07:53 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
