Sals Rebuild in NC - Defender Source
Old June 23rd, 2015, 11:02 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
Sals Rebuild in NC
I'm pretty sure my Salisbury is about to grenade any day now. It chunks, clunks, and bucks as the truck rolls to a stop. Who do you recommend in NC (prefer West of the Triangle) that can rebuild my rear diff at a reasonable price?
Thanks guys!
Bo
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old June 23rd, 2015, 11:13 AM
rovertrader's Avatar
rovertrader
Dale
I have a Sals with new pinion seal/bearing and new cover available if you want to go that route. PM if interested as I am out of town.
Old June 23rd, 2015, 12:14 PM
Probably drive flanges. I have never seen a sals wear out. Check the drive flanges first.
Old June 23rd, 2015, 12:33 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
It is essentially a Dana 60, so a local R&P shop should be able to do it easily.
-Jeff
Yup, technology/design is the same however you may have to help them source the rover unique parts.
Old June 23rd, 2015, 05:24 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
Would it be cost effective to upgrade to a locker (ARB) now that it's giving me trouble?
Old June 23rd, 2015, 05:36 PM
Hey Bo, in Charlotte i can recommend Performance Rovers. I'd recommend identifying the root cause before throwing money at it. I'd hate for you to find out it was a driveshaft, Tcase or wheel bearing issue after directing axle work to be done.
I'm assuming you're talking about your rear axle, right?
Mark Kellgren
KM4BOR
Old June 23rd, 2015, 07:30 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
Thanks Mark, I met Jason at the Spring Safari and got his business card.
I had a local shop look at it and say it needed a complete rebuild or replacement. I'd rather have a reputable Rover shop give a second opinion and do the required work.
Old June 23rd, 2015, 07:59 PM
I agree. To just say it needs a full rebuild without telling you how they came to that conclusion is suspect. We're talking half shafts, wheel bearings, diff and pinion. you can swap an axle out in 30 minutes if the splines on it were worn. that would be far short of a full rebuild.
Mark Kellgren
KM4BOR
Old June 24th, 2015, 07:57 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
I'm with you, Brother. I'll pull the wheels off and check the flanges and outer axle splines this weekend like Briggsy and the Ninja suggested (sounds like a pop duo).
I've always been a "hope for the best but plan for the worst" kind of guy.
Old June 24th, 2015, 08:10 AM
slorocco
Dan Prasada-Rao
If you do have to get it rebuilt and have been wanting to upgrade to a locker, then this would definitely be the time to do it.
rebuild
Sals pinion nut loose D90user Defender Technical Discussions 1 August 17th, 2009 04:26 PM
Front truetrac and rear sals. truetrac or detroit D90user Wanted 1 October 29th, 2007 12:55 PM
Looking for sals rear axle ChicagoDon Wanted 1 March 28th, 2007 07:52 AM
Sals. pinion seal D90user Defender Technical Discussions 0 March 15th, 2007 01:01 AM
Sals in Kansas pendy For Sale - Parts 0 March 29th, 2005 12:01 AM
