Sals pinion nut loose - Defender Source
Old August 17th, 2009, 04:19 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
So driving up to Oregon this weekend I noticed a whine on deceleration. Pulled over the the rear pinion was loose and gushing oil. I pulled the prop shaft and axles and re-tigtned and re-stakedthe nut (which was really loose) then continued the rest of the trip in front wheel drive.
I drained it and there were a good deal of shavings on the magnet and in the oil (new oil ~500mi). From what I could see in the hole there are no chunks out of the ring but I couldn't see much.
So the question is what to do now? Is it just stupid to not strip it and at least replace the crush sleeve? Or is there a chance that I can just flush it out, hook it up and continue on my merry way?
Any advice on how to do this myself with only "normal" tools?
By the way the diff and bearings only have about 40k on them.
cheers!
Old August 17th, 2009, 04:26 PM
New crush sleeve would be a minimum if it were mine as well as a new locknut.
OTOH, I saw a sals that drove though the better part of Australia that was filled with water and about two tablespoons of oil and it was fine .
Pinion Seal Leak, Salisbury Diff Doug Defender Technical Discussions 18 August 8th, 2016 03:07 PM
Sals. pinion seal D90user Defender Technical Discussions 0 March 15th, 2007 01:01 AM
Rear Pinion slack flippedrover Defender Technical Discussions 4 September 12th, 2005 10:07 PM
GBR 4.75 Ring & Pinion RedRhinoProducts For Sale - Parts 1 January 25th, 2005 02:16 PM
Lug Nuts!!! Get loose today !!!! Vadim Defender Technical Discussions 10 October 26th, 2004 03:58 AM
