Salisbury Pinion Seals/assembly - Defender Source
Old October 7th, 2013, 03:47 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Ok so I already posted this over on my build thread but haven't had any feedback yet, so hopefully someone will see this over here.
So I have just refinished my axle housing and need to re-install the differential, problem is I didn't take it apart and need some clarification on order of parts and what actually needs to be replaced.
Here is what I have figured as to the order parts go back in from looking at pictures:
  1. Inner pinion bearing (will replace)
  2. 2x shims that sit between the inner pinion bearing and the casting
  3. Collapsible spacer (should it be replaced?)
  4. Outer pinion bearing (will replace)
  5. Washer
  6. Oil seal ( I think mine must have been a leather one but hard to tell since the leather is gone)
  7. Gasket
  8. Flange (possibly replace)
  9. Washer
  10. Locknut
  11. I also have some rubber boot thingy that was in with the diff parts is this part of it?
I have attached a picture so hopefully someone can verify I have this straight.
So my next question is should I be replacing these with the same seal kit or should I be upgrading to the newer Flange Kit STC4403, or STC4457 (can't tell the difference between the two).
If I am to upgrade to this new system what parts does it eliminate?
Thanks in advance, I'm in a little over my head on this one.
Will
ID:	81714   Click image for larger version
ID:	81716   Click image for larger version
Old October 7th, 2013, 05:30 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
The input gear doesn't look "right" to me. the teeth seem excessively worn.
Mike Hammond
Old October 7th, 2013, 06:07 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I don't think it's that worn, but it does have a bunch of surface rust after the last owner left the diff in the back seat.
Here is a better picture. Let me know if I'm totally wrong and I should be looking for a new pinion.
ID:	81720   Click image for larger version
Old October 7th, 2013, 06:16 PM
PM me your email and I will send something that should help. If the flange is snug on the splines, they should be fine. I am not sure about the updated flanges. I know people use dana 60 seal in place of the leather.
Old October 8th, 2013, 05:45 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
The Land Rover Series III manual has rebuild instructions.
http://www.scribd.com/doc/64476604/L...ies-III-Part-5
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 8th, 2013, 10:33 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Thanks! evilfij just emailed it over to me last night. It will be a big help!
What I'm still curious about is if anyone here has installed one of the Flange Upgrade kits on an older axle. Part # FTC4557
If so do you still use the Pinion Oil slinger (washer) and oil seal gasket or do they get ditched?
Will
Old October 8th, 2013, 02:44 PM
mikeslandrover
Mike Hammond
The new pics show the parts in a better light. Rebuild it & see what happens, might need an oil change sooner rather than later as the rust gets warn off once you start running it.
Mike Hammond
assembly, seals
Pinion Seal Leak, Salisbury Diff Doug Defender Technical Discussions 18 August 8th, 2016 03:07 PM
Salisbury pinion drive flange f**king thing o2batsea Wanted 12 August 6th, 2012 07:03 AM
110 Salisbury Diff cover AaronOwens Wanted 2 November 8th, 2005 01:34 PM
Rear Pinion slack flippedrover Defender Technical Discussions 4 September 12th, 2005 10:07 PM
GBR 4.75 Ring & Pinion RedRhinoProducts For Sale - Parts 1 January 25th, 2005 02:16 PM
