Salisbury pinion flange replacement question - Page 2 - Defender Source
Join the Defender Source Community Today
Old June 17th, 2015, 12:28 PM
Etienne's Avatar
Tdi 2500 diesel Defender 1985
On my diff (salisbury) I had to use a 3 ton bottle jack and a 32 socket welded to a 25mm roundbar about a foot long to get that nut to move. Had to jack up the socket against the Landy's weight to get the nut to budge. I found a seal at the engineering supplier , black pvc no metal double lipped with innerspring tensioner measuring 80mm outer & 47mm inner, intended for some or other truck. In $'s it cost $2.00. It fitted well with no leaks to date. Do you really have to buy that weird land rover seal?
Old June 17th, 2015, 07:50 PM
carlosz's Avatar
my past experience has taught me that if I pull the flange with a crush sleeve behind it, the only way to properly reassemble is by installing a new crush sleeve. other wise you are asking for trouble.
the time and money spent on installing a new sleeve is less than the headache and extra expense on having to replace damaged diff internals due to improper pinion preload because of a used crush sleeve.
Ring/pinion/flange smob For Sale - Parts 0 September 20th, 2013 04:03 PM
DII pinion flange question Tyler Wirken Defender Technical Discussions 11 July 26th, 2013 12:06 PM
Salisbury pinion drive flange f**king thing o2batsea Wanted 14 August 6th, 2012 06:03 AM
Series R&P 4.70, pinion flange and spacer ring KevinNY For Sale - Parts 0 January 20th, 2011 11:17 AM
Pinion flange TDI Guy Wanted 0 June 1st, 2009 05:21 PM
