Salisbury parts - Defender Source
Old October 18th, 2015, 12:56 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
Salisbury parts
Pinion bearings went on my rear diff. Found out my rear driveline is more oval shaped than round. I've done a bit of research and many say the Salisbury is a pain to work on, suggesting you should take it in to a diff shop.
If I'm having someone dig into this thing, what should I replace? I've ordered front and rear pinion bearings, carrier bearings, leather and metal diff seal, rear cover gasket, and pinion seal. Drive line is also on the way.
What else is a good idea to pick up?
Old October 18th, 2015, 01:11 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
The hardest part is that you can't pull the third member and put it on the bench. Your choices are either work in place under the truck, or pull the whole axle and put it on the bench. If you've got to play around with setting pinion depth it can sometimes take a couple iterations in and out.
Old October 18th, 2015, 02:01 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
You can get a modern type pinion seal. I'd go that route rather than the leather.
-Jeff
I've heard of using a dana 60 seal but is there an LR part #?
Old October 18th, 2015, 03:25 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I bought my pinion seal from GBR
Old October 18th, 2015, 03:26 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
No but there is a non-LR part number...
Old October 18th, 2015, 03:37 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
Dude, glad you're back. Call so I can stop stalking you. I can help you obtain an anti-harassment order if you need one.
Old October 25th, 2015, 10:12 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
I dropped the rear end out today and, this may come as a shock, salisbury diffs are not indestructible. I don't know what the previous owner did to this thing but it's hard to imagine it was done with a 2.5 na.
part, parts
Salisbury drum brake parts Abrooks Wanted 10 September 4th, 2012 06:45 PM
Dana 60 parts in a Salisbury axle? nopants Defender Technical Discussions 10 May 4th, 2011 07:18 PM
FS Salisbury Drum Brake Parts Stmpede For Sale - Parts 3 December 18th, 2008 08:02 PM
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Disc braked rear Salisbury axle Shane@EVS For Sale - Parts 2 August 6th, 2004 05:59 PM
