Salisbury HD Axles - Page 2 - Defender Source
Old January 26th, 2013, 12:43 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by 130Tdi View Post
I have a detroit in mine and have tried to push the 130 through some "extreme" rock gardens @ The Cove . I have broken both shafts a couple of times. I keep going with stock as I view the shafts as kind of like a fuse that I'm blowing. If I wrap the fuse with aluminum foil and put it back what will I break then (Ie hardened shafts) and because the stock shafts are $25 ea.
I run $400 HD KAM shafts in my rear Sals with an ARB and 4.10s running on 35s. Never had an issue. For $400 it's worth it not getting stuck in a precarious place or changing a shaft in the mud.
Semper Fi!
Old May 23rd, 2013, 04:49 PM
sunny every day
Martin
ex-mil 1980 series 3 LWB RHD FFR 2D
TerriAnn.
Didn't you put the Torrel Industries disc brake conversion kit on your LR from Mountain Expedition Equipment ?
So do you think the ROAM kit is just better ? or better financially ?
Thanks.
Old May 24th, 2013, 11:56 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Originally Posted by sunny every day View Post
TerriAnn.
Thanks.
Would like the same info too...
Old May 24th, 2013, 12:05 PM
Maybe you guys should PM Terriann.......
Old June 14th, 2013, 12:38 PM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
TerriAnn.
Yes I did. What I can say is that the kit is very complete even including special sockets that can be hard to find. They assume that you don't need wheel bearings but just about everything for the conversion is in the box. The kit was an easy bolt on. If you have ever replaced wheel bearings the project is basically the same.
I have a web page that goes over the conversion.
I have no experience with a ROAM kit. I have not seen one nor driven a LR with the kit installed to I am not qualified to give an opinion.
The Torrel kit is more complete than the ROAM kit and I think is under half the price, possibly even 1/3rd the price by the time you put the wheels back on your truck.
To date I have been happy with the Torrel conversion. Especially coming out of a water crossing or stopping and holding a 109 on a steep nose up position. Holding a 109 still in a steep nose up position is very difficult with stock drum brakes.
TeriAnn
axle
GBR or similar axles for Salisbury axle 110 or regular front diff.. the rover shop Wanted 26 October 26th, 2012 10:32 PM
Salisbury 110 / 90 Front and Rear Axles for Sale SafariHP The Vendors Loft 0 July 4th, 2011 03:20 PM
Ashcroft HD axles with flanges d90dang For Sale - Parts 3 April 18th, 2011 11:29 PM
HD axles question wantone Defender Technical Discussions 28 February 27th, 2011 01:05 AM
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
