Salisbury Detroit locker install how to - Defender Source
Old March 16th, 2009, 05:27 PM
Anyone have a write up? I have "heard" you just pop it out and pop it back in as there is no need to reset up the gears but I don't know.
Ron
Old March 16th, 2009, 06:55 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Take the diff out, take it apart, take out the spiders, put in the DL, put the diff back together, remove the wing nut and long bolt holding the DL together, put the diff back in, glue the fancy new Dana 60 diff cover on and fill with oil.. You're done. 1 hour, no set up required.
Keith
Big, Red and ... aaa Red..
Old March 16th, 2009, 07:25 PM
SWEET.
You got any brackets for calipers in stock Keith?
Ron
Old March 16th, 2009, 07:36 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Not in stock.. Perhaps the easiest way is to buy some from your favorite parts guys and have them shipped to me. I'mm mill them and turn them around pretty quick.
It's such a low volume thing I just can't justify stocking them, I don't even get a good enough deal to buy them in bulk.
Or buy them and have you favorite machinest mill .120" or so from the caliper mounting side. It's too simple.
Keith
Old March 16th, 2009, 11:28 PM
Keith, are there axle shafts available that I can run with alloys?
Old March 17th, 2009, 03:14 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
I think you emailed me the same instructions a few years ago when I bought my DL. My DL is still sitting on my work bench. Thanks for the reminder.
Old March 17th, 2009, 11:54 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Probably the best solution for this other than wheel spacers is to convert the front end to post 1994 spec stuff. In other words the hubs, stubs, halfshafts and CV's from a Disco or D-90 as we get them, you'd also have to put a 24 spline diff in. The rest remains.
In the rear again it's hubs stubs and Shafts at the same time you'll do the disc brake conversion, the wierdest part you'd have to find is the stubs axle, which is common in the ROW for the Disc brake Salisbury post (wait for it) 1994. This allows fitment of the shorter drive flanges from the later trucks..
Or clearance the wheels. the dust cover will always poke out near as I can tell though.
The biggest problem with pre 1994 stub axles is the I.D. it's 1.25" in diameter, later trucks had a bigger 34mm (ish) bore that allows the easy to make axles fit without clearance issues.
Keith
Old March 18th, 2009, 05:21 PM
JSQ's Avatar
JSQ
Jack Quinlan
I heard that when you put the DL in the sals you need a case spreader.
Old March 18th, 2009, 05:28 PM
yeah, I'm unclear about this case spreader thing too - I've heard comments ranging from "need the right tool" to "big screwdriver." Sounds like a hassle.
Old March 19th, 2009, 08:17 AM
Cube II's Avatar
Cube II
Michele
1997 D90
A long time ago, in galaxy far far away...erm I think someone posted on Pirate about a free hand technique to pull the diff out with no need of the spreader...
Pendy maybe?
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old March 19th, 2009, 09:53 AM
Bunched up rag between the crown and pinion, then rotate to push the carrier out. At least that i what I have heard. Getting it back in though might be interesting.
Pendy maybe?
Old March 19th, 2009, 03:40 PM
JSQ's Avatar
JSQ
Jack Quinlan
Bill Davis told me to just prybar it under one of the ring bolts.
My other friend said the spreader makes it about 100 million times easier.
Old March 19th, 2009, 04:05 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I use a crow bar to pull them out and a soft hammer to put them in.
Or you can use a speader which does make things loads easier. You can even use a propane torch to head the area that the cover bolts to, once it get's warm enough the case will spread thermally (about 180 degrees)
Keith
Old March 23rd, 2009, 08:59 AM
propane? that must take a while
all this is making me want to put one in the 109. though it hardly needs it since it never leaves the driveway...
Old March 23rd, 2009, 10:35 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
Can someone comment on how the effects of the DL acts on short wheelbase vehicles as opposed to long wheelbased. I have heard they are better in a LWB truck. Anyone with firsthand knowledge?
Old March 23rd, 2009, 11:12 AM
Cube II's Avatar
Cube II
Michele
1997 D90
I almost went straight out of a turn first time I tried Keithís black Disco
Canít say about a 130 though, those I drove were stock
Michele
D90 VNTdi
[O]===[O]
Old March 23rd, 2009, 11:23 AM
exmod110's Avatar
exmod110
Don Lang
I have a rear D.L. in my 110 and unless the tcase is locked i have found that it didn't really affect the road manners too bad. with the front wheels also pulling (awd) it takes the stress off the rear axle and it doesn't seam to bind like it dose in a 2 wheel drive application.
detroit locker
ARB locker install problem... Heath Defender Technical Discussions 10 January 12th, 2007 08:35 PM
Need ARB locker install manual dave_lucas Defender Technical Discussions 13 December 6th, 2006 11:05 AM
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 12:25 PM
3rd - Detroit Locker 4.10, 2" Rovertym Springs, Bodylift - Parting out Mudrover mudrover For Sale - Parts 6 July 18th, 2004 03:38 PM
4.10 gears and Detroit locker dave_lucas For Sale - Parts 3 December 1st, 2003 03:03 PM
