Salisbury Cover Bolts - Defender Source
Old June 29th, 2009, 09:22 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I need to replace the cover bolts with 3/8"x1" UNC (is this correct) to install my Slickrock rear diff cover (Thanks Dave, amazing fabrication work on this!) and was wondering if they need to be grade 8 or if 18.8 Stainless would do for this application? (The originals are fairly hard to read so I cannot identify the grade easily).
Old June 29th, 2009, 12:08 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
IIRC the bolts are M10X25 and don't see why you could not put in SS I did with no ill effect on my ARB DANA60 diff cover.
Pat
Kirk Lazarus, Tropic Thunder
Old June 29th, 2009, 12:12 PM
ajh
Andrew J. Hutton
Odd, they seemed to match the UNC bolts I put them up against in the store. Hard to drag the diff in to make sure though I will pick up one of each and confirm, thanks.
bolts, cover
Salisbury Diff Cover Bolts - ARB Diff Cover Shearpin Smaller Projects 4 February 20th, 2008 03:52 PM
97' D90 steering column plastic cover bolts januconn92 Wanted 0 April 8th, 2006 03:56 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
110 Salisbury Diff cover AaronOwens Wanted 2 November 8th, 2005 01:34 PM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
