Salisbury Backlash How much is Normal? - Defender Source
Old April 13th, 2015, 08:38 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
So today I was in the process of pulling my rear axle out that will be going on my new chassis and while I had the backend of the truck jacked up I noticed what if you spun one wheel it seemed to me like a fair bit of rotation before the other wheel engaged.
I've taken a little video here, the handbrake is on so the drive shaft isn't moving and I'm showing the amount of rotation before the other wheel engages.
Is this a normal range?
I'll be checking the drive flanges, half shafts which I know can all contribute but I'm hoping I don't have to get into that diff and add to the never ending list of things to do.....
Oh and if you missed the title it's a Salisbury axle.
Thoughts?
Old April 13th, 2015, 09:11 PM
Check the drive flanges first. They wear out and cause a lot of backlash.
Old April 13th, 2015, 09:13 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I will check them tomorrow. Does the movement i'm showing seem way out of norm?
Old April 13th, 2015, 09:25 PM
No idea. Can't see the video on the phone.
Just pop the caps off the flanges and rotate the tires. See if the wheel moves more than the half shaft.
Old April 13th, 2015, 10:04 PM
Finally watched the video. That is a normal amount of wheel movement.
Old April 13th, 2015, 10:08 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Excellent news. Thanks for the info.
I'll certainly be checking the drive flanges regardless as I've seen how they wear.
ac
How much is too much??? Azarur Truck Build-up's & Restores 71 April 5th, 2015 01:55 AM
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Sagging Suspension: How Much is Too Much? aclarke Defender Technical Discussions 9 June 19th, 2007 04:41 PM
Steering Wheel backlash adjustment Mike Finn Defender Technical Discussions 0 December 20th, 2005 12:07 PM
Rockware trailing links, backlash artm Defender Technical Discussions 1 June 14th, 2005 03:59 PM
