Salisbury axle question HELP!!!!! - Defender Source
Old October 18th, 2015, 05:36 PM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
So had a leak on the rear of my 89 110, coming out both axle shafts, started replacing the seals at the hubs today. Missed the sir clip as I was in a hurry, pulled the 5 17mm bolts and went to pull the cover and then realized it when the axle shaft started to come out with the cover. Pushed it back in after pulling the sir clip off, but must have pushed it in too far as upon reassembly there isn't enough of the axle shaft to put the sir clip back on. Have tried to use the sir clip to help pull it back out but it is hun on something. Any ideas? Have had suggestions of putting a self tapping screw into the end of the axle to help pull it out. ?????
Old October 18th, 2015, 06:01 PM
Remove the flange and pull the half shaft out and put back together.
Old October 18th, 2015, 06:06 PM
wanabewheelin
Michael Sword
have the flange off and an inch or so of the shaft is sticking out, but it is stuck, put the sirclip on to give me something to pull on and it is still hung on something . . .
Old October 18th, 2015, 06:23 PM
Pry or tap on it. Maybe spin the other wheel. It won't be in there hard. The shaft is very strong. You won't hurt it.
Old October 18th, 2015, 06:52 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
If all that fails pull the shaft out on the other side and get a long rod small enough to stick through the opposite side and through the diff. You should be able to tap it out that way. That trick worked for me on the broken front Salisbury shaft with an ARB in it. I used a long piece of all-thread to poke through and tap the broken shaft loose. I think I used something like a 1/4" all-thread.
Old October 18th, 2015, 11:11 PM
wanabewheelin
Michael Sword
Thanks Dan, that did the trick ... used an old metal broom handle, LOL a few taps with a hammer and popped right out, she was stuck in there pretty good for some reason.
All wrapped up. Time to hit the hay
Old October 19th, 2015, 07:19 AM
slorocco
Dan Prasada-Rao
Glad it worked for you man.
axle
Pinion Seal Leak, Salisbury Diff Doug Defender Technical Discussions 18 August 8th, 2016 03:07 PM
Salisbury pinion flange replacement question Wilboro Defender Technical Discussions 19 June 17th, 2015 08:50 PM
Salisbury Carrier Bearing Question LR Max Series Technical Discussions 0 November 8th, 2013 04:38 PM
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Disc braked rear Salisbury axle Shane@EVS For Sale - Parts 2 August 6th, 2004 05:59 PM
