Sagging doors - Defender Source
Old June 15th, 2016, 01:27 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Sagging doors
Not that the 94 defender doors were ever at the "rolling ballbearing" level, mine have now regressed to a double clump clunk due to sagging. Lift at edge of door while opened is in the 1-2 inch range.
Apreciate any suggestions / leads and like to go stainless for hardware.
Thanks in advance
Old June 15th, 2016, 01:29 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Have you checked any of the bolts for tightness and attempted to adjust the doors at all?
You little rebel, I like you.
Old June 15th, 2016, 01:33 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
That was my first thought as well, check the easy stuff. Bolts and shims are tight.
With as much play as there is I'm assuming bushings
Old June 15th, 2016, 02:58 PM
Grover's Avatar
Grover
Wow, that's a lot of play dude. I'm amazed that much is possible. I'd say your hinges are toast. Post some pics...
door
Sagging arse end. '85 90 SW Paul K Defender Technical Discussions 11 August 6th, 2014 08:03 PM
Sagging Footwell Toe Box Liner - Suggestions? Manimal Defender Technical Discussions 28 August 8th, 2009 09:21 PM
Sagging Suspension: How Much is Too Much? aclarke Defender Technical Discussions 9 June 19th, 2007 04:41 PM
Switch-out HT Doors w/ ST Doors 1of40 Defender Technical Discussions 11 May 2nd, 2005 09:04 PM
Replacing sagging Headliners in Defenders - material and success? COSteve Defender Technical Discussions 8 April 27th, 2005 05:41 PM
