Safety devices rack - rust spots - Defender Source
Old November 13th, 2015, 03:50 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
I have two exceptionally annoying rust spots on the basket and I've tried all the OTC stuff, metal rescue and naval jelly, etc.. I have no interest in hauling this thing to a powdercoater cause of the dumb cost and the effort to get it there. Once rust is out, I'll just rattle can it.
Anyone run into this problem with old SD parts? Advice on the best chemicals to get rid of it? Maybe a big drill and a wire brush? Thanks.
-Ren Ching
Old November 13th, 2015, 04:03 PM
Probably 100 ways to skin this cat but I would Scotch Bright pad the area, phosphoric acid then rattle can it.
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Unless it's a weld or a hard to reach corner, I would think sanding it would be a heck of a lot easier than a wheel. Flappers and angle grinders make fast work of it all, but If it's just on the surface, you'll be down to bare metal pretty quick! Just prime and paint. That's how I saved all the guards on my RRC.
Old November 13th, 2015, 04:11 PM
smob's Avatar
smob
Steve
Thanks guys, heading out to the hardware store now for the supplies.
-Ren Ching
Old November 13th, 2015, 06:56 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I'm surprised a wire brush (possibly drill operated) + naval jelly + POR15 + Rattlecan wouldn't work. My concern would be using the Naval jelly->POR15 up on the roof and it getting where you don't want it.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old November 13th, 2015, 08:17 PM
Naval jelly?
Is that like ky?
Old November 13th, 2015, 08:18 PM
smob's Avatar
smob
Steve
I bet that a wire brush would do it, but tomorrow i'm going to try scotch brite pad and phosphoric acid.. if that fails, then wire brush to start.
-Ren Ching
Old November 13th, 2015, 11:46 PM
D90Overkill
David Frank
1995 ST #2615
Originally Posted by Rocky View Post
Naval jelly? Is that like ky?
Only if you're blonde and bruise you're girlfriend's belly button! ;-)
ac, rack, safety devices
What wire gauge do i need for my spots? leastonce Defender Technical Discussions 6 February 7th, 2013 09:09 AM
Just bought 2007 Jaguar Super V8, please buy my other cars so I have parking spots evilfij Misc. Chit-Chat 13 August 30th, 2012 11:49 AM
Fitting Safety Devices Roof Rack With Oem Swing Out Tire Rack LONDONNAS Defender Technical Discussions 3 August 29th, 2009 04:38 PM
3 oil spots under center differential {...} ini88 Defender Technical Discussions 3 September 27th, 2006 03:46 PM
