SafariGard droop kit - Defender Source
Old April 15th, 2005, 02:28 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Anyone have one of these installed? Cna you take pictures of the installed unit. I kit used and it looks pretty straight forward but a picture never hurt.
Joe
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old April 15th, 2005, 02:43 PM
Don't know if you saw these ones
http://www.safarigard.com/catalog/sg...it_2410486.htm
Old April 15th, 2005, 05:03 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
I saw those, but I am trying to figure out where the bushing goes. Does it sit above the spring perch?
Joe
Old April 15th, 2005, 07:57 PM
redrover
Guest
Posts: n/a
Joe it goes above as you stated. also tach weld the 1/4"round plate into place on the top of perch. I also had to ground the spring cap so that it would slide in and out of the spring perch easier. jp
kit
Rate/type of the SG droop kit coil Cube II Defender Technical Discussions 0 November 27th, 2009 04:10 AM
Used Safari Gard Droop kit dmarchand For Sale - Parts 2 September 17th, 2006 09:37 AM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
SG Droop kit knowledge? dmarchand Defender Technical Discussions 5 October 3rd, 2003 10:53 AM
