safarigard bumper install questions. - Defender Source
Old September 1st, 2007, 08:21 PM
Firefighter2904's Avatar
Firefighter2904
jason
97 d-90
Just curious for the folks out there with a safarigard bumper, how did the install go?
It says on there web site you have to cut parts of the frame off and also have to take off cooler lines.
This stuff all true? Do you have to disconnect the cooler lines or drop them? any advice on install.
Jay
PS I did use the search button and didnt have luck finding exactly what I needed.
Old September 1st, 2007, 09:19 PM
CDN22's Avatar
CDN22
Ken
1994 D90
I removed the 'horns' with an angle grinder in about 10 minutes... very easy to do. I do not recall having to mess with cooler lines on a 94 ST.
Hope this helps.
Old September 1st, 2007, 10:18 PM
Firefighter2904
jason
97 d-90
i guess i should add mine is a 97
Old September 2nd, 2007, 10:55 AM
CDN22's Avatar
CDN22
Ken
1994 D90
Jason,
Thinking about this a little further you DO unbolt the lines and reattach after installation. Again, not difficult at all.
Cheers.
Old September 2nd, 2007, 11:02 AM
Firefighter2904
jason
97 d-90
did u have to drain them ? or just unbolt them from a bracket?
Old September 4th, 2007, 09:44 AM
CDN22's Avatar
CDN22
Ken
1994 D90
Just unbolt.
Old September 4th, 2007, 11:33 AM
I had to cut the fram horns and the bottom off my grill and change to an aftermarket transmission cooler on my 97 ST. I have the brush bar that works with the Husky winch. I think the warn version is slightly different.
Old September 4th, 2007, 11:43 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I had to cut one of the side tabs on each horn for mine to go on the 97 and the 94.
Chris von C
[/size]
Old August 9th, 2011, 06:52 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Hay I know this is an old thread but....I am installing the Safarigard bumper and skid on a 110 Tdi. In test fitting the bumper I had to cut the outer side tabs to get it to slide on to the frame rail. The question I have is it looks like to get the skid plate bracket to install I will have to cut a little more? Any suggestions?
Land Rover 110
Old August 9th, 2011, 09:09 PM
The skid should not require any cutting, but I had to cut off the frame horns and relocate my trans cooler.
Old August 9th, 2011, 09:32 PM
Capt Milks's Avatar
Capt Milks
Thanks, I had to cut the frame extensions, jack point, to get the bumper on and to clear the skid.
Dopes anybody know what winch fits best? Looks like the warn wont work unless the brackets are modified. I will also need some recovery points. Looks like the bumper has two 5/8 holes.
Land Rover 110
Old August 10th, 2011, 01:26 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I have a Warn in my SafariGard bumper with no issues... but who knows there may have been different versions.
bumper
Planning Amp Install - some questions Chaucer Misc. Chit-Chat 7 February 25th, 2010 04:00 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
PIAA 90 PRO XT (top) install questions... norros Defender Technical Discussions 22 June 30th, 2004 05:31 PM
Rockware Install sherpamike Defender Technical Discussions 15 December 24th, 2003 06:05 PM
