Safarigard 3-link rockguard BEWARE ! - Defender Source
Old April 25th, 2007, 10:02 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
I just replaced both 7/16 bolts used in the rockguard mount to diff housing. Both bolts had sheared off and the broken studs took some time to remove. To all with a SG 3-link please check your hardware . Symptoms , knocking sound ,clicking sound when brake is applied . Once again please check your hardware , other than this problem I'm very satisfied with the performance of the 3-link .
Old April 25th, 2007, 10:18 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It should take over 30,000 LB of force to sheer off two 7/16 bolts. Something was very odd.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 25th, 2007, 10:54 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I think Keith drove for a while without the center attatched after the toy convert. IMHO
To shear 2 7/16's grade 8 bolts takes some doing! They were grade 8's?
Old April 26th, 2007, 03:35 AM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
One possible explanation, based on something I've encountered. Those bolts seem to have a habit of getting loose. Generally I hear this pretty soon, crawl under the truck, and tighten them back up. But if they were allowed to stay loose, especially for an extended time, you'd have the RockGard bashing against them. They'd be subjected not just to shear, but to bending as well.
Also, are they really 7/16"? I seem to remember something about those being an unusual pattern, maybe BSF? It's been awhile, but I seem to remember that part (maybe all) of the problem I was having stemmed from someone along the line replacing them with the wrong threads.
I don't have the SG 3-link, just the stand-alone RockGard, but I believe the attachment design is identical.
Old April 26th, 2007, 07:17 AM
Cirbo's Avatar
Cirbo
Jim C.
Those symptoms are very similar to worn bushings on the radius arms. Could that kind of play contribute to the failure?
Old April 26th, 2007, 07:34 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I have had to re build several brand new SG 3 links were the rock guard attaches to the diff due to the mounting being far from close (1/4-3/8) from the diff housing. If the 7/16 bolts are used to draw this gap tight it does leave the bolts under some fairly high tension , and probably more likely to break.
I've installed many of these and SG are well aware of the issue......they claim sloppy manufacturing tolerances at the Rover axle assembly line......shocker.
Matt Browne
Old April 26th, 2007, 08:29 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I too have installed 3-4 of these & I shim the gap before I snug the bolts & red locktight the shit out of them.
Old April 26th, 2007, 08:48 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Could you guys expand on this a little more? I need to replace the bushings and suspect the bolts as well since my 3-link has been showing wear and allowing the front axle to rotate a hair back and forth. I'm planning on addressing this hopefully in the next few weeks and would like to hear more of what people are doing.
Chris von C
[/size]
Old April 26th, 2007, 10:36 AM
Ray Bone's Avatar
Ray Bone
Ray Bone
defender.
Jorge! did i see you on Ave B or C time to time? where do you fix your truck? in the city?
I have some problem with my 90, I need some advice..
Bone
Old April 26th, 2007, 12:02 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Were the correct bolts installed? So it had been tapped up to 7/16?
JP
legend in my own mind
Old April 26th, 2007, 01:41 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I still have an unsupported rock gaurd (no bolts) things seem to be holding well and I fequently try to bend the thing with no success . I will at some point take it out and add some metal to reinforce if I don't change the whole thing out for something different first.
Keith
Big, Red and ... aaa Red..
3-link
SafariGard 3 link front suspension cdb Defender Technical Discussions 36 June 8th, 2009 08:01 AM
Home design 3 link system UKlandyandy Defender Technical Discussions 65 February 17th, 2005 09:09 PM
Fusable Link by batt on 92 RRC...? RedRhinoProducts Defender Technical Discussions 5 February 6th, 2005 07:23 PM
