Safari Roof ON D90 - Defender Source
Old March 7th, 2011, 02:12 AM
DD90's Avatar
DD90
DD
94 D90
Safari Roof ON D90
Can a safari roof bolt on to a D90?
If it can, where is best place to source them?
Old March 7th, 2011, 05:50 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I have only seen them on 109's. If they put them on an 88 I would think that it may be a little too short for a D90.
Land Rover 110
Old March 7th, 2011, 10:16 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
It will not bolt on unless you get a series windshield as well. The 90 roof is curved to form and fit the windshield and the series roof and windshield are flat. I am pretty sure after that it should relatively fit.
Can I ask why? Looks? Just curious.
Old March 7th, 2011, 10:24 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
If a guy really wanted to, I don't see why you couldn't bend up a sun sheet and screw one on to the 90 roof.
These things ain't the Space Shuttle we're drivin'
Old March 7th, 2011, 10:37 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Like Keith said, just fold a sheet of metal. Use plastic or aluminium spacer and bolt it.. Voila!
Old March 7th, 2011, 02:32 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
The D90 windscreen is curved??? Looks pretty flat to me but maybe in a different plane.
Don't mind converting to the series windscreen if needed but may be "too much" work for the benefit.
Wanted to get some nice ventilation going in the summer. I have AC in the summer but also hate the heat almost as much.
Old March 7th, 2011, 02:42 PM
grnrvrs's Avatar
grnrvrs
Paul
88
You mean like this? http://www.defendersource.com/forum/...referrerid=670
To cut down on the summer heat, try better insulation for the roof first.
Old March 7th, 2011, 04:57 PM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
Hi, the series screen and defender screens are interchangeable. But an 88" roof is 5" shorter!
mark one yourself but getting an ali sheet bent up and space it aout an inch off the roof.
Old March 8th, 2011, 04:46 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Alternately, source an early ribbed roof, then you can just screw the shade sheet right to the ribs.
The curve Tyler is talking about is the top of the windscreen, reflected in the roof skin.
The vents that go in the inner roof are still available, but not cheap. Something similar could be fabricated without much effort.
Tony
1984 110 "Smokey" (sold)
Old March 8th, 2011, 07:12 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
I wouldn't put that amount of efforts to put a second skin on the roof. It will vibrate and you're better of insulating the actual roof. I manage to put about an inch of urethane between the roof skin and the trim. It work like a charm. Cuts down heat in summer and cold in winter as well as stopping vibration so, less noisy!
Old March 8th, 2011, 09:37 AM
specops1526's Avatar
specops1526
Beluga '97 90
It looks like you have a 94 D90. So you either have an ST with a fiberglass top or a POE. I'd say bolting something to the fiberglass top isn't going to work and if you have a POE roof, I wouldn't ruin it with a project that includes a piece of aluminum that was never meant to be bolted to it.
If this has nothing to do with looks, then I'd say try insulating the roof like others have said. Maybe try some Dynamat and see how that works first before you start drilling and ripping things apart.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
90, d90, roof
D90 Full Safari roof rack jvelador For Sale - Parts 4 October 13th, 2008 08:28 PM
Safari Roof Rack for D90 Soft Top tahoe4x4 Wanted 0 April 26th, 2006 02:16 PM
Safari Roof Rack wanted for ST Cyborg Wanted 0 March 18th, 2006 04:54 AM
97 d90 sw roof wanted steved90 Wanted 4 December 30th, 2004 12:54 PM
WANTED: NAS Safari Roof Rack m.michaels Wanted 3 November 10th, 2004 11:34 AM
