Safari Gard Hitch opening - Defender Source
Old August 30th, 2007, 04:50 PM
themaxx's Avatar
themaxx
Ade
94 ST
I have a Safari Gard rear bumper and the hitch (assuming it's a class III, 2in opening) needs to be a tad bigger on the inside. Any suggestions on what to use to open the hitch mouth. I assume I need some type of grinder or shaver, but what?
Old August 30th, 2007, 06:02 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
How much is a tad? You could use a metal file. But that would be by hand.
Old August 30th, 2007, 06:07 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Ade - If it's the same problem I had (I also have a SafariGard receiver), it's a mismatch of the corner radii. The receiver inside corners have a larger radius than the outside radius on the hitch corners. I ended up grinding a bit off the hitch as it's much easier to do that. My hitch is solid (not tube) so it had no affect on strength.
Old August 30th, 2007, 09:55 PM
themaxx's Avatar
themaxx
Ade
94 ST
Great quality control!
Ryan, what did you use to grind it?
Old August 31st, 2007, 12:56 AM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I think it's just a matter of where they get their tubing for making the receivers. There's just a guideline that foundries generally use for establishing the corner radius of tube stock (generally less than 3X the wall thickness). So it can vary depending upon the source, and of course, thicker wall tubing will have larger corner radii.
I just used a Makita 4" disc grinder with a flapper wheel. It really didn't take too much as you're just trying to match the radius area.
Also, it's hit-and-miss on whether things will fit in the receiver or not. I have a hitch-mount bike rack that fits with no problem.
Old August 31st, 2007, 01:16 AM
themaxx's Avatar
themaxx
Ade
94 ST
Just picked up a Thule T2 bike hitch that after forcing it, only fit maybe an 1.5in into the receiver. Needing a hitch extender for the bike rack, the extender wont fit all.
I'm going to modify the extender and just use it from now on. I'll give the grinder a go tomorrow.
Thanks for the info!
Old August 31st, 2007, 10:34 AM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
I ground down my hitch too. Sucks I know.
Michael Slade
www.tawayama.com
Old August 31st, 2007, 11:49 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
x2 on grinding the hitch. Pretty poor quality control.
Old August 31st, 2007, 02:48 PM
themaxx's Avatar
themaxx
Ade
94 ST
Ryan,
You were right on the money! Took the hitch extender to a local Tool & Die shop to trim the corner radii down. After he spent 10 minutes drooling over the Defender (he had a cool jeep setup) he used a special bit and reshaped the corners.
Thanks for info!
Ade
Old August 31st, 2007, 08:16 PM
NashvilleRedD90's Avatar
NashvilleRedD90
Will Peters
'97 NAS D90 ST #1704 -4.6
I've had that problem. Actually on my D90's stock receiver bumper thing. My trailer hitch has be be pounded in and out with a hammer (so I don't use it on my D90 anymore), but my shackle bracket thing slides in and out no problem. Actually it has enough room you can wiggle it around.
On my D2 I have a SG bumper with the integrated receiver and the same receiver shackle bracket thing fits very tightly, you can still fit it without a hammer but its snug...
'97 D90 - 4.6
'00 D2
hitch
Safari Gard National Press Release SafariGard The Vendors Loft 18 June 19th, 2009 09:37 AM
safari gard stuff GeoParth Wanted 2 November 21st, 2005 02:15 PM
Safari Gard equipped Defender for sale JAZZIQC For Sale - Vehicles 5 July 30th, 2004 11:41 AM
Interesting one for Sale on Ebay--the Safari Gard OCD90 Misc. Chit-Chat 8 April 13th, 2004 12:32 PM
Greg and Brandi Jevne chrisvonc Defender Owners 0 February 22nd, 2004 09:38 PM
