Safari Equip auxiliary tank thoughts... - Defender Source
Join the Defender Source Community Today
Old May 12th, 2011, 05:49 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
I'm seriously considering getting the Safari Equip SEL 72A aux tank for my 90. It is an in-line model and holds approximately gallons. It fits back of the wheel well and comes with everything needed to hook it into the stock tank.
I have been in communication with Safari Equip and that think that I need the 50mm (2inch) hose version but they also have a 60mm (2.5") hose version. My 90 is in the shop- anyone care to do me a favor and measure their 90's fuel filler hose?
Any thoughts on this unit?
Name:	90 LR Tank E-Mail.jpg
Old May 12th, 2011, 07:18 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
how many gallons??? what are they asking for it??
thanks
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old May 12th, 2011, 07:23 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
8 gallons
Old May 12th, 2011, 09:33 PM
now that is interesting -
when you say in-line does this gravity feed into the main tank? there are no transfer pumps from the picture.
do you fill this tank seperatly from the wheel well? or is it filled via the main tank fill?
Do you have a price from them (i'll drop them a mail as well) since it is not on the website apparently.
------ Follow up post added May 12th, 2011 07:50 PM ------
ok it looks like the Fuel filler pipe is 57mm and the hose it joins into the fuel filler hose running to the tank is 67mm wide respectively.
From the pictures it looks like this tank would join directly to the fuel filler pipe and join to the stock tank where the fuel filler hose comes in.
It would ride on top of the stock tank and gravity feed into the stock tank.
let me know if i'm right in my thinking here.
Adding 8 gallons would extend my range by apx. 100 miles - the fuel gauge would read Full for an extended period of time as the Aux tank drains into the stock tank.
I'm really interested in this (i.e. now top of my list of things to buy for the 90 now)
95' D90 - daily driver..
Old May 12th, 2011, 10:09 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
I'm getting approximately 2.5" for the hose from the filler to the tank.
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old May 12th, 2011, 10:12 PM
cdb
Clark Bowen
Not sure since mine is a diesel now, but I thought there were some smog related items back there that blocked using that tank. I do know of a D110 300 TDI with that tank and he loves it.
2011 RR HSE -
2001 GMC 2500 4wd
Old May 13th, 2011, 08:12 AM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
Yes, the tank is gravity feed. They make a few different versions based on the size filler pipe you have. I know they have a 50mm and a 60mm version. I'm trying to get some clarification as to what exactly should be measured- the filler pipe or the attached hose. I believe the measurement that is needed is the pipe on the stock tank which I am not sure is the same at the filler pipe (where the gas nozzle goes). I would imagine that these measurements (tank inlet and filler pipe neck) should be close. After I figure that out, I'm going to order one as I am happy to be the guinea pig.
Old May 13th, 2011, 09:12 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Yes. Please keep this saga updated. This is one of my biggest issues with the 90: range. I would definitely think about doing this if it indeed works well.
Old May 13th, 2011, 09:33 AM
Arjun
Arjun
If you have a roll cage, make sure there isn't intereference with the roll cage and the aux tank where the cage bolts to the frame. I looked at a similar gravity tank for my 110 and had to ditch it because there was interference with the cage leg that bolted to the frame on the right hand side. The aux tank went into the right hand side rear wheel well.
Henry Stinson in Toronto has a similar tank in his 110, but no cage so it works fine.
Old May 13th, 2011, 11:16 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I have a similar tank on the 110. It is great.
Be cautious of the roll cage supports for NAS trucks and tire size requirements. It would be impossible to go larger than 33's with mine and with 33's it is really really close when the wheel is stuffed.
I really want a pair of their belly tanks for the 110.
Old May 13th, 2011, 01:13 PM
93' NAS 110- #234
One of these rear arch tanks is on my want list as well. There are several makers of them in UK and SA.
I just haven't resolved the issue of clearance with roll cage mounting yet.
And yes, at least on an NAS 110, there is an evap collection tank in that right rear wheel well. Mine is getting yanked out when I put this tank in eventually as I've gone diesel. Petrol rovers are going to be problematic.
Old May 13th, 2011, 03:59 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
I've ordered the tank...will let you all know how it goes.
Old May 13th, 2011, 04:05 PM
93' NAS 110- #234
I will say that this arch tank is different in design from the others I have seen, such as the front runner version.
I actually don't see the 72A tank, or any rear arch tank for a 90. safari equip was one of the companies I was looking at for a rear arch fuel tank, but for a 110.
Old May 13th, 2011, 04:22 PM
which size did you order the 60mm?
Old May 20th, 2011, 02:14 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
I just wanted to update this thread in case anyone was considering this upgrade.
The Safari Eqip tank will indeed fit in the rear passenger wheel well on a NAS Defender. There are a few issues that need to be dealt with. First off, at least on my 1994 ST D-90, there is a charcoal canister mounted on the frame. This will need to be relocated as it will prevent you from correctly mounting the tank. Secondly, although the instructions say that you can install the aux tank without dropping the main tank, it seems to be nearly impossible to do this.
So, my mechanic will do the install and I'll have him drop the tank and relocate the emissions canister. All in all, I still feel that it's worth the time to get an extra 8 gallons so I plan to continue with the install.
Hope this helps!
Old May 20th, 2011, 02:43 PM
Reese_D90's Avatar
Reese_D90
Reese
Any chance of getting some good picures of the install?? Please keep us posted.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old May 20th, 2011, 05:57 PM
Chaucer
Will
93 110 | 97 90
Does this particular tank require you to install a balance line between the two tanks?
Old May 20th, 2011, 07:37 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
Here are some pics...
Name:	90 Td5 Wing Tank E-Mail (1).jpg
ID:	38905   Click image for larger version
Name:	90 Td5 Wing Tank E-Mail (2).jpg
Name:	90 Td5 Wing Tank E-Mail (3).jpg
ID:	38907   Click image for larger version
Name:	90 Td5 Wing Tank E-Mail (4).jpg
Name:	90 Td5 Wing Tank E-Mail (5).jpg
ID:	38909   Click image for larger version
Name:	90 Td5 Wing Tank E-Mail.jpg
Old May 20th, 2011, 09:54 PM
Is your truck blue or yellow?
Old May 21st, 2011, 05:46 AM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
It's yellow. The pics posted are from the manufacturer. My install will happen in a couple of weeks since it's more involved as I thought it would be.
ht
Safari Gard D-90 gas tank support bar Tyler Wirken For Sale - Parts 2 July 2nd, 2008 04:50 PM
Safari Equip Tire Carriers w/ Highlift Mount FS New SafariHP For Sale - Parts 7 November 4th, 2007 08:32 AM
FAO:Buckon37 or any air tank user... Cube II Defender Technical Discussions 9 July 4th, 2005 03:05 AM
Aux tank and LR winch bumper Jase For Sale - Parts 10 July 1st, 2005 05:38 PM
Safari Gard equipped Defender for sale JAZZIQC For Sale - Vehicles 5 July 30th, 2004 10:41 AM
