Safari Equip auxiliary tank thoughts... - Page 3 - Defender Source
Old May 13th, 2012, 10:45 AM
Wondering about extra protection from stones etc kicked up by the tires
Old May 13th, 2012, 12:18 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
I don't think it would fit with that cage support.
-T
Any idea if it will fit a SW?
Attachment 51492
------ Follow up post added May 13th, 2012 12:19 PM ------
A metal skid-plate/protective piece is included to protect the under side of the tank.
Old May 13th, 2012, 03:52 PM
-T
Is there any clearance on top? I could have someone make me a cage support with a different shape.
Old May 13th, 2012, 04:46 PM
Mendicant
That extra bit on the cage is really just there for the jump seats, and most (like on the NAS 110) are just installed with stiff-back plates. I wouldn't hesitate to modify that cage piece to make clearance. You could reinstall the seats using rivnuts into aluminum or steel backing plates so at the seats could be removed without dropping the tank.
Old May 13th, 2012, 06:42 PM
Thanks Jim ... I think it's the seat belt mount point as well ... Is that the same on the NAS 110? I don't mind mounting seats on a riv nut but seat belts?
Are stockpiling defender bits for your return?
Old May 13th, 2012, 08:25 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
clearance...
You've got a little less the 4" of clearance at the top. See attached pic...
-Tim
Old May 13th, 2012, 08:51 PM
-Tim
Super ... I think that should be enough, if it's not I'll sake the route JimC suggested.
Thanks very much for the photo!
Also did you get the 50mm or 60mm version?
Old May 13th, 2012, 08:59 PM
Best measure to the rib, but sounds like it's a non-issue if you are willing to remove the bar (I think a backing plate for the seatbelts is plenty myself).
Originally Posted by pendy
I'm here for the D's
Old May 22nd, 2012, 06:27 PM
50 or 60mm?
Old May 22nd, 2012, 06:54 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
50mm if I remember correctly...
Old May 22nd, 2012, 07:52 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
Tim,
Have you had a chance to wheel it on some trails? I'm curious about rubbing issues at full stuff.
Abe
Old February 10th, 2013, 08:20 PM
My tank is now here and I'm hoping to install this coming weekend.
Old February 10th, 2013, 08:34 PM
Tough one. Two cans inside secured or an addition to the fuel tank located outside the chassis rail or a series tank added.
How much did this solution
Old February 10th, 2013, 08:36 PM
Are Uptown and Downtown Manhattan really that far apart that you need this?!
Old February 10th, 2013, 10:45 PM
I'm looking to get 700 miles between full ups when my 300tdi is here.
Old September 28th, 2013, 06:36 PM
Wildcat's Avatar
Wildcat
Nick
1997 Defender 90 SW
Did you ever install the tank on your SW? Were any modifications necessary in order to install it properly?
Old September 28th, 2013, 08:02 PM
I haven't done it yet ... But a few simple mods will be required. Relocation of carbon filter for existing fuel tank and possibly seat mount bracket.
Old September 28th, 2013, 08:46 PM
Wildcat's Avatar
Wildcat
Nick
1997 Defender 90 SW
Keep us posted once you do install. Pictures are nice too.
Old December 8th, 2013, 12:00 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Bump for more from Jason (when he gets the chance).
Old December 8th, 2013, 09:20 AM
Ok so this took me around 6hrs to do. I took my time and didn't rush. The kit is very good and was pretty much complete. All I needed extra was some hose to extend one breather tube and 2 nuts and bolts to fasten the tank clamp. Mine is a SW so I had to remove the seatbelt section on the roll bar undertake he arch. The new fuel filler is without and anti-siphon top ( basically I can see the gas ) but I'm thinking about modifying the old one to restore this. The worst part although not technically difficult is drilling a hole in the unobtanium NAS gas tank for balancer tube.
Also tricky is putting the inside fitting for the gas tank. You have a length of welding wire that you push down the filler and out the hole you drilled. Once in place you slide the internal fit tint down the wire and pull it through and put the external washer and nut on. This is more fiddly that difficult but if you get it wrong you will have to drop the gas tank to fish it out.
If anyone has any questions please ask!
Sorry for the crappy selection of photos ... It's all my little helper took!
ID:	85566   Click image for larger version
ID:	85568   Click image for larger version
ht
Safari Gard D-90 gas tank support bar Tyler Wirken For Sale - Parts 2 July 2nd, 2008 05:50 PM
Safari Equip Tire Carriers w/ Highlift Mount FS New SafariHP For Sale - Parts 7 November 4th, 2007 09:32 AM
FAO:Buckon37 or any air tank user... Cube II Defender Technical Discussions 9 July 4th, 2005 04:05 AM
Aux tank and LR winch bumper Jase For Sale - Parts 10 July 1st, 2005 06:38 PM
Safari Gard equipped Defender for sale JAZZIQC For Sale - Vehicles 5 July 30th, 2004 11:41 AM
