S1 discovery vs S2 transfer case - Defender Source
Old August 7th, 2008, 10:36 AM
turbodave
Dave C
1983 110
I'm looking at a transfer case locally, but the guy believes it came off a 1999 - but doesn't know if it's a s1 or S2. Is there a clear visible difference between the two? This is for swapping out the 1.6 transfer case on my '83 110...
Cheers,
Old August 7th, 2008, 10:43 AM
Yes, the front flange is larger on a DII. The one on a DI is the same size as the one on your truck.
Old August 7th, 2008, 11:49 AM
turbodave
Dave C
1983 110
So are there any bolt holes / measurements, or anything else I can easilly Identify (my 110 is still on a ship - LOL).
Here are some pics the guy just emailled me. He knows about as much as me. He did reference it's a 10-spline input.
http://www.davecoxon.co.uk/tc_1.jpg
http://www.davecoxon.co.uk/tc_2.jpg
http://www.davecoxon.co.uk/tc_3.jpg
http://www.davecoxon.co.uk/tc_4.jpg
http://www.davecoxon.co.uk/tc_5.jpg
Old August 7th, 2008, 03:17 PM
ashtrans
Dave Ashcroft
it's not a D2 LT230, let me know the serial number and I can confirm the spec,
Dave Ashcroft
Old August 7th, 2008, 04:00 PM
turbodave
Dave C
1983 110
The serial number is found where? ?He said he looked but couldn't see...
Got it...
http://forums.lr4x4.com/index.php?showtopic=16590&hl=
Old August 7th, 2008, 04:22 PM
ashtrans
Dave Ashcroft
http://217.34.53.228:9876/uploads/230sno.wmv
Dave Ashcroft
Old August 7th, 2008, 05:13 PM
I am pretty sure that is a late disco I with the later speedo sensor. Dave Ashcroft can tell you if you can switch your rear housing over to make it work with the mechanical speedo. I know it can be done with an early 1.22 case to a late 1.22 case, but with the 1.6 I am not sure.
Ron
PS, I would reseal it before using it and you have to remove the solinoid on top if you want to use low range.
Old August 7th, 2008, 11:27 PM
turbodave
Dave C
1983 110
oooh, electronic speedo... I had no idea the S1 discovery's went to an electronic speedo. Hopefully Dave A can shed some light on this. I would throw some new seals on it for sure.
Old August 8th, 2008, 12:38 AM
pendy's Avatar
pendy
jim pendleton
89'd90
The electric speed sensor just plugs into the speedo gear. You can remove the speedo gear from your other box if the inner speedo cable size is different between the different gears.
Or better yet change to electric speedo now. Egauges.com
legend in my own mind
Old August 8th, 2008, 03:34 AM
ashtrans
Dave Ashcroft
Hi,
as Jim says the speedo will be no problem and as mentioned you will need to remove the solenoid,
are you sure you want to go from 1.667 to 1.211 ?
the engine may struggle to pull this higher ratio,
Dave Ashcroft
Old August 8th, 2008, 09:41 AM
turbodave
Dave C
1983 110
Jim, Dave, Great information. Thanks!
The 110 has a TDi in it, with the LT77 - and I will likelly be knocking up a new intercooler, exhaust and tweaking it slightly before too long.
Looking at the ratios (assuming I've used the right numbers) the 1.2 looks like a reasonably good match with the LT77 for 1st gear ratio - comaparing to a R380 with a 1.4 Tcase...
Fifth is noticably taller, but I'd sooner have it this way than too short - if it is too tall for any instance, I guess a shift to fourth would do the job.
Here is a comparison I knocked up previously of the overall ratios showing the logic behind my madness.
http://www.davecoxon.co.uk/LT77_vs_R380.jpg
Old August 8th, 2008, 04:19 PM
ashtrans
Dave Ashcroft
Hi,
if the 200 tdi engine is healthy and the tyres not too big I would think it will be OK with the 1.2,
I though you had the original 1983 2.5 N/A,
Dave Ashcroft
cover, disco, discovery, transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
