S/W rear door question - Defender Source
Old April 9th, 2009, 08:44 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Does a 95 s/w rear door have a 3rd brake light in the door? If so, any pictures of where it goes and what it looks like?
Legend in My Own Mind.
Old April 9th, 2009, 09:03 AM
Yes, they do have them. I've got some pix from the 110, and they seem to be basically the same (maybe a different housing).
I lied, can't find pix. All I've got are some of a dismantled door.
Old April 9th, 2009, 11:06 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I have the complete assembly from my '97 SW if you're interested in buying one, $30 + freight.
Dennis
Old April 9th, 2009, 12:34 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Cool. Sounds good.. Dennis, do you have a pic?
Old April 9th, 2009, 12:49 PM
photo?
Old April 9th, 2009, 06:15 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
how does it attach inside?
Old April 9th, 2009, 06:26 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I believe there are two studs that have to be glued to the window itself (similar to a rear view mirror) and then the housing attaches with a couple of nuts to secure it. At least that is how it appears in the exploded parts diagram. The NAS 110 one is different and has two brackets that screw directly into the door frame above the window.
Old April 9th, 2009, 07:15 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
huh.. interesting..
Old April 9th, 2009, 08:53 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
This is the same setup as the '97's. Randy, you can buy an LED version with the enclosure and glue that to the window.
Old April 10th, 2009, 12:29 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Randy, I believe I bought one of these:
http://www.jcwhitney.com/Third-Brake.../600003037.jcw
The one at the top of that page for $15.99. Works well, no complaints. Just super glue on the glass and be careful not to get the glue on the heating elements depending on which type of door and glass you are using.
Old April 11th, 2009, 12:55 AM
Ray Bone's Avatar
Ray Bone
Ray Bone
defender.
sw
You have to glued on it, Andrew is right.
door, rear door
S/W Rear seat belt Parts TDI Guy Wanted 8 June 18th, 2009 05:01 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
