S/S Window Stud Frustration - Defender Source
Old December 4th, 2005, 01:47 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Well, I finally got my stainless steel window studs last week. Unfortunately, the door tops are nearly un-removable with these new studs. A friend and I spent an evening bending the old rusty studs so that the windows came off more or less cleanly. I'm debating whether I should just live with the very poor fit or sell the S/S studs and put the old rusted things back on.
Is there any way to bend the new s/s studs, the female-threaded door top sleeve, or the in-door sleeve? Anybody else had this problem?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old December 4th, 2005, 01:54 AM
Is your configuration different that the 95? I dont understand the problem...
Old December 4th, 2005, 02:24 AM
chris snell
Chris Snell
87 Ex-MOD 110
Not sure about the 95. The problem is, we purposely bent the old studs to make the window tops go on/off smoothly. Now that I have new, straight S/S studs, the window tops are very difficult to remove. I don't think that I will be able to bend the new S/S studs, at least not easily. I'm wondering if there is another solution, like somehow repositioning the channel (sleeve?) that is built into the top of the door frame.
2013 LR4
Old December 4th, 2005, 03:13 AM
Scott 9835
Scott Falter
95 D90
Try Removing one of the plastic sleeves. There should be two per door. They slip over the studs. I removed one from each door and it makes fitting the windows alot easier and when they are tight they dont rattle
Old December 4th, 2005, 09:38 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Also take a round file and do a little work on the holes in the door. Mine stick after I put them in for the winter but then again I also keep a pry bar in my tool box mostly for popping the windows. Also grease the studs.
Jimmy Buffett
Old December 5th, 2005, 08:20 AM
scoloco's Avatar
scoloco
'94 D90 ST
When I put my stainless steel studs in, the plastic sleeves wouldnt fit - they went into the bag with the old studs. I got mine from GulfCoast or JTEK. No rattles. Although taking the original ones was a b1tch.
Old December 5th, 2005, 11:06 AM
jstrong98's Avatar
jstrong98
Jon Strong
I took all the plastic sleeves off for easier install/ removal. Get a fat O-ring that is the same ID as the OD of the window bolt and slide up to the window frame.
JS
Old December 5th, 2005, 09:16 PM
chris snell
Chris Snell
87 Ex-MOD 110
Actually, the GCR S/S studs do not come with (nor need) plastic sleeves. The problem with mine is not so much the internal diameter of the door sleeves, it's that something is misaligned. Either the sleeves in the doors are misaligned (doubtful) or the threaded reciever in the door tops is misaligned. To make the factory studs work properly, I had to grind them down AND bend one of them approx 5 degrees. Something is very wrong with my window tops.
Why do the studs have to fit so snugly? Wouldn't it be sufficient to allow them a sligtly loose fit (easy insertion) and tighten the nut down snug to keep the window from rattling?
2013 LR4
window
ST Window Stud mikeybob2@msn.com Wanted 0 April 25th, 2009 07:31 AM
FS: SoftTop window stud sleeves mpodgorski For Sale - Parts 2 August 18th, 2008 06:40 PM
Window removal 1/2 way there Help!! paulb Defender Technical Discussions 2 May 11th, 2005 04:13 PM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
plastic window stud sleeves jstrong98 Wanted 4 October 22nd, 2004 10:24 PM
