Rusty sheet under gas/brake/clutch - Defender Source
Old October 6th, 2013, 10:50 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hi all. Check out the rust. I snapped a quick photo but didn't think to look if it was rivited or welded in. Is this part easily replaced? Just some stock sheetmetal cut to size? Any thoughts would be greatly appreciated.
Old October 6th, 2013, 11:03 PM
Footwell repair panel. Weld in. Job done.
Old October 6th, 2013, 11:23 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks guys. Is this the weld in repair piece? Or am I just simply looking for a piece of flat sheetmetal?
http://www.urbanlandcruisers.com/sho...pair-panel-ns/
Old October 7th, 2013, 01:18 AM
There are actually two pieces. That one and the reinforcing one. Check out roversnorth as they seem to have the ones closes to factory.
Old October 7th, 2013, 10:55 AM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
Anyone have a link to a detailed footwell replacement thread? Did a search already, everyone just says "Weld the new footwell in, ta- da"
Curious about how easy/hard footwell replacement is without removing bulkhead or stripping the vehicle down, and how to paint the footwell inside and out.
Old October 7th, 2013, 11:18 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Your pick looks a lot like my footwells on the driver and passenger side. For mine, instead of welding in a new footwell box, I just cut out the bad metal, and shaped a piece for the repair. You'll need to remove your floor tins and the bolts and plastic nut inserts will need new ones(easily purchased). Once I welded them in, I then used seam sealer on both sides and then primer painted the metal. On the exterior I used a 3M product for painting your tire wells and it works great.
I would also suggest that you replace your bulkhead vent seals unless you can confirm that the rust came from the outside in. I chose to go with the Series rubber ones versus the original felt.
Old October 7th, 2013, 11:20 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Awesome advice! Thanks!
Old October 7th, 2013, 11:56 AM
There is an upper surface and a lower surface.
The upper surface is basically just bent sheet metal.
The lower surface is a waffle-shaped reinforcement plate that attaches to the back side.
brake, clutch, gas
Sheet metal terminology and [hand] tools cgalpin Misc. Chit-Chat 16 January 31st, 2010 11:19 AM
Rusty Door Bottom landrovered Defender Technical Discussions 6 April 6th, 2009 04:59 PM
5 Bar Sheet NashvilleRover Defender Technical Discussions 6 October 17th, 2007 06:13 PM
Rusty Nail easy Trips, Trails and Events 0 May 5th, 2005 12:52 PM
Rusty Capping dbwitt Defender Technical Discussions 2 February 14th, 2004 05:32 PM
