Rusty Door Latch - Defender Source
Old March 10th, 2011, 11:34 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Rusty Door Latch
What is the best way to deal with a rusty door latch, or any part with similar corrosion? Is it possible to clean or is replacement the way to go?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 10th, 2011, 12:34 PM
The two pieces to the left/right that are backing plates/retainers can be replaced cheaply, and when you remove those you can clean up the latch and paint, but I think the latches are pretty cheap as well iirc.
Originally Posted by pendy
I'm here for the D's
Old March 10th, 2011, 12:58 PM
Grover's Avatar
Grover
Thumbs up
This is what I did:
Replaced the nut retaining plates, they are cheap.
Wire brush the latch to rid the loose rust, neutralize it with POR or something similar, then paint it.
When re-assembling, make a gasket from pond liner or hot-tub liner to separate the retaining plates from the door. You may want to get new door latch gaskets as well, they are cheap.
Also, check the door latch cavitiy, odds are it is starting to rust as well as it is made from steel.
Spray Waxoyl 120-4 in the door latch cavitiy where it meets the aluminum panel and let it wick into the seams.
Good luck...
Cheers...
door, door latch
Superwinch X9 drum rusty Manimal Defender Technical Discussions 6 November 8th, 2010 11:42 AM
Parts from your old rusty bulkhead dave_lucas Wanted 14 September 23rd, 2010 11:22 AM
Wanted - very rusty 110SW 2nd row doors oilburner Wanted 1 September 10th, 2010 09:45 PM
Rusty Nail easy Trips, Trails and Events 0 May 5th, 2005 12:52 PM
Rusty Capping dbwitt Defender Technical Discussions 2 February 14th, 2004 05:32 PM
