Rusty Capping - Defender Source
Old February 14th, 2004, 05:14 PM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
Rusty Capping
Anyone have any suggestions regarding rusty capping. I know it is not uncommon. My SW is a 95 so there is no warrenty left. Can it be sanded and repainted or do you need to replace it the capping? It is a pretty big job taking the top off and I would rather not. Any suggestions would be helpful.
Darrin Witt
95 D-90 SW
04 Disco
Old February 14th, 2004, 05:18 PM
There is a write up on removing the Station Wagon top, it may be of interest. I do not know anything about the body capping.
http://www.defendersource.com/mod/sw2st/index.htm
Old February 14th, 2004, 05:32 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
You basically have 2 options to fix it correctly.
1. Remove the roof and roof panels to remove the cappings. You would then need to get them balsted to remove the rust, and repaint, or galvanize and repaint them.
2. LR has started offering a 1 piece side capping. The one you have is more than likely 2 pieces. The weld on the 2 piece one is where most of the rust starts. The 1 piece capping eliminates that particular problem. Also, these cappings are now available galvanized from the factory.
Either way, if you want it fixed correctly, the roof has to come off.
Hope this helps.
Fitting D110 Body Capping mattarm Defender Technical Discussions 9 July 19th, 2010 07:43 PM
rear 110 body capping WhiteD90 Wanted 10 May 6th, 2008 11:25 AM
Rusty Nail easy Trips, Trails and Events 0 May 5th, 2005 12:52 PM
Galvanised tub capping jabber Defender Technical Discussions 9 March 3rd, 2005 09:35 PM
body capping on rear tub WhiteD90 Defender Technical Discussions 5 October 6th, 2004 06:10 PM
