Rusting Bulkhead on a 110 - Defender Source
Old April 14th, 2007, 03:48 PM
Spectre
Stephen
'76 SIII Lightweight
Unhappy Rusting Bulkhead on a 110
I was wondering if anyone would be able to give me some suggestions on how to fix a rusting area on a bulkhead. Right now, money is too tight for total replacement and its probably not needed (rust seems to be confined to this area). Has anyone had any experience either welding, repair or filling this or could give any meaningful suggestions? Thanks in advance!
-Steve
PS- I do have some bubbles on the door, so I need those need to be fixed as well, but the bulkhead is priority #1 at this point.
ID:	8994   Click image for larger version
Old April 15th, 2007, 10:21 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Have you pulled the black vinyl cover off the kick panel on the inside? The rust on mine was up near the rubber vent fillers (NAS 110) but it turned out that whole support piece was rusted away at the bottom pretty bad, and yours looks like it might be worse than mine was. If it is just the outside, I would take the doors and fenders off and grind away the rust and use a rust converter before repainting it. It isn't a permanent fix, but will slow it down and buy you some time till you replace the bulkhead completely. Also, check the crevice where the front floor panels meet the bulkhead floor (this is where water always pools and causes a lot of cancer).
Old April 15th, 2007, 11:47 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
That actually looks pretty bad to me. My bulkhead had no external signs at all that there was a problem untill the floor rotted away. Check where Andrew mentioned by where you put your feet. Then be sure to take the window off (one piece) and check under that as well. If you want to fix it right, I would pull the front fenders, door, and windhield. Cut off the areas that are rusting, weld in new pieces and use liquid steel as a filler. If you do all that you could have a repair that lasts for 10 more years. It would be easy to do yourself, the only thing that would really cost you is to repaint but you could probably find a deal on just the bulkhead.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 16th, 2007, 12:00 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Like Buck said, it does look pretty bad and a bulkhead isn't all that exp. The killer would be the labor if you can't do the work yourself, but it shouldn't be that bad either since you don't have the NAS dash to deal with! I would check with George and see if he has one you can buy.
Old April 16th, 2007, 04:08 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
What are you looking to spend? I woudl do a complete bulkhead for sure..
Legend in My Own Mind.
Old April 16th, 2007, 04:52 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
That looks pretty bad to me. I condemed a bulkhead that had no rust on the door pillars but when I pulled back the rubber mats from the toe boards...fresh air. Easy to say from this side of the pond, I picked up a good 300 tdi bulkhead with steering column at the Old Sodbury Sort Out for 80 and then sold the steering column for 15 on the day, but that's another story.
I think you can get door pillar repair sections and probably the whole footwell as a repair section too.
Also check carefully below the wind screen nder the foam sealer strip, thats another favorite spot for rusting quietly away unseen untill it's too late
Mike Hammond
Old April 16th, 2007, 06:14 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
since you don't have the NAS dash to deal with! it is a pain in the ass!
Andrew does your 110 have alloy's on it????
Old April 16th, 2007, 06:39 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Not now...I have a set, but haven't decided if I am going to put them on or not. I think I am going to refinish the steelies and swap the tires off the alloys onto the originals. Why? Are you looking for a set?
Old April 22nd, 2007, 09:41 PM
Spectre
Stephen
I was thinking of something like this might be effective. I have poked around quite extensively and the rust does seem to be somewhat confined. I do need a new radiator as it is disentigrating.
http://www.eastcoastrover.com/93phase3.html
Diamond the Dormobile 110 evilfij Truck Build-up's & Restores 85 May 31st, 2013 09:14 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
bulkhead LHD 1993 defender 110 non ac with extras haaseizhere For Sale - Parts 15 March 4th, 2007 10:23 PM
