rusted/pitted spindles - Defender Source
Old June 5th, 2008, 12:06 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I bought a complete axle housing w/ toyota conversion for the rear. It sat outside for several months and the spindles are pitted. The guy who sold it to me said to just clean it up with brake cleaner. Would it be bad to use a wire brush or similar to remove the surface rust and then clean it up with brake cleaner, or should I get new spindles and have Keith machine those?
Also, I am confused with the terminology. They are spindles, but are they also called stub axles? I have heard people refer to the short axle shafts on the front axle as stub axles. Please enlighten me.
Old June 5th, 2008, 01:36 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I'd clean them off and try some emery cloth to polish them up first.
Old June 5th, 2008, 02:36 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I can fix those..
Keith
Big, Red and ... aaa Red..
Old June 5th, 2008, 02:42 PM
Pish, they are fine.
Ron
Old June 5th, 2008, 02:46 PM
Gore Ranger
Jeff
1989 RRC
Originally Posted by revor
I can fix those..
maybe I can bring them up because I was also hoping you could machine the flanges on the shafts too so they'll fit under the aluminum rims??
Old June 5th, 2008, 04:27 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
In LR lingo they are called Stub axles. The shaft on the CV joiny is called the CV's axle stub by some.
No problem bringing them by machining the shafts takes about an hour. The stubs shoudl take about 15 min. Do have your Toy third yet? The drive flange will need mods that take about an hour.
Keith
Old June 5th, 2008, 05:43 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Try polishing them with some Scotchbrite - they may clean right up
Old June 17th, 2008, 11:17 AM
Gore Ranger
Jeff
1989 RRC
This is the flange I took off the toyota 4 cyl differential that came with it (that diff was welded so I am not going to use it). Is this the correct one for the Rover conversion?
Old June 17th, 2008, 12:28 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
That should work!
Keith
Hub and Spindles.. Are they The same TDI Guy Misc. Chit-Chat 4 October 7th, 2009 08:17 AM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
