Rust Resistant Door Hinges - Defender Source
Old April 10th, 2011, 06:02 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Mine are rusting and needs to be replaced. There seems to be some choices out there. What is the part # for the ones that are least prone to rust? The MXC8284 ones don't seem to rust resistant. Paddock has a set of zinc coated ones: Door Hinges The price is certainly right but are these any good?
Some have mentioned TD5 hinges being more rust resistant. What is the part# for those?
Old April 10th, 2011, 06:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
I think ecr is making an alloy one. Not sure if they plan to sell but they look factory and I assume wont rust. I would want those.
Old April 11th, 2011, 12:17 AM
Chaucer
Will
93 110 | 97 90
It looks like from pics on the web that the ECR alloy hinges are the same or similar to the Croytec hinges: http://croytec.co.uk/products/DoorHinges.htm
So you're looking at around $500.00 for two doors. You probably can't buy a better set though.
Old April 11th, 2011, 02:29 AM
TS888's Avatar
TS888
Tony Sims
1984 110
There are some alloy and SS options in the UK. Alloy is better choice for avoiding galvanic action with the Birmabright panels.
A corrosion proof Landy is usually seen right after a unicorn.
Tony
1984 110 "Smokey" (sold)
Old April 12th, 2011, 08:37 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
We'll have some out soon. The prototypes are done and being wear cycle tested. They will be somewhat less expensive than those alloy versions currently being produced. First full run should be mid to late May (this year).
Matt Browne
Old April 12th, 2011, 09:00 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Cool! Who are "we"?
Old April 14th, 2011, 07:58 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
I hope "we" makes enough to go around
Old April 14th, 2011, 08:11 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Yes, we are working with John to make "NAS" alloy hinges. Here is the first set. They already make excellent Td5 style hinges that we use on Wagons, but on the soft top cars to use the Td5 hinges it means you have to grind the door capping (making another potential rust spot). So we worked with John to come up with a NAS hinge that is the correct size and shape as the original, but made from better materials. Everything is done on them and the design is well tested (he has been doing Td5 style for years). You can order them direct from John or get them through us. The cool thing is that he has a NAS 90 in the UK, so he was able to test fit everything over there.
Email:
Old April 14th, 2011, 08:14 AM
kevkon's Avatar
kevkon
kevin
How did you handle the hinge pin? Is there a bushing?
Old April 14th, 2011, 08:19 AM
ECR's Avatar
ECR
Hinge pin is SS and grease-able and rebuild-able. There is a spacer on both side so that the hinges do not "grind" on each other (that was the cause of the rust in the originals).
We've been using these style of hinges on customers Nantucket cars for a few years now, and they have been great, and if they survive out there they are just fine.
Its croytec's design, we just had them adapt it to fit NAS 90 soft tops better.
The Td5 hinges are also very good. We used those for a lot of years (and still do for those who don't want to pop for the alloy units) with no complaints from customers:
http://www.eastcoastrover.com/Hinges.html
Those are:
BDB710200
BDB710210
BDB710220
BDB710230
and you'll need at least 8 shims BDC710040
Email:
Old April 14th, 2011, 09:19 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Any ideas on price points ?
Old April 14th, 2011, 10:46 AM
ECR's Avatar
ECR
That will be up to John, we don't have the info yet.
Email:
Old April 14th, 2011, 11:04 AM
Maybe one of us smart folk on this site will cast some up from filled epoxy. Aluminum powder and milled carbon fiber? Vacuum cast? Should be an easy thing.
Old April 14th, 2011, 12:29 PM
Chaucer
Will
93 110 | 97 90
ECR - Very nice product indeed!
door
Rust Management loykd Defender Technical Discussions 44 February 5th, 2010 11:00 PM
rust on SW top overlap kolvedic Defender Technical Discussions 0 December 5th, 2005 01:51 PM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
