Rust removal, new way - Defender Source
Old April 13th, 2010, 07:48 PM
artm
Arthur Maravelis
97 SW
Anyone ever try this product?
http://www.safestrustremover.com/default.asp
It seems obvious - chemically remove the rust instead of converting it! The beauty is that it minimizes removal of parts as it can be sprayed or showered on, as shown in the pics. Furthermore, it doesn't damage rubber, paint, glass and, I think, plastic.
Of course, you can dip anything small or removable in it but how about the bottoms of doors to get into all the seams!
You can spray it on anything including all those rusty bolts and other areas requiring spot treatment.
Showering and recirculating the liquid over anything large is very appealing. I'm thinking of spraying the liquid through the frame and then over it before treating it with Waxoyl and paint.
Old April 13th, 2010, 09:05 PM
KKilo23's Avatar
KKilo23
Kenny
I am skeptical. My life would be a lot easier. I guess its worth a try... .
Old April 13th, 2010, 09:39 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
I have wanted to try this for a while. I will get around to it eventually.
Old April 13th, 2010, 10:08 PM
me too!
as soon as I find a bath large enough to immerse my whole truck
Old April 13th, 2010, 10:14 PM
Naval jelly works-sort of. I like sand blasting for quick gratification.
Old April 13th, 2010, 10:35 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
It does have a money back guarantee... I'm curious now.
Old April 14th, 2010, 12:03 AM
artm
Arthur Maravelis
97 SW
Here's another apaprently good solution, more easily obtainable and cheaper:
http://www.evapo-rust.com/
Only good for dipping though.
Old April 14th, 2010, 01:02 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Someone should do a taste test of these products for D90. I would, but I am drunk and won't remember this in the morning...first night in a couple weeks I have not wrenched....kind of nice...
Old April 14th, 2010, 10:06 AM
I did. It worked ok for superficial/surface rust but not for anything else.
Old April 14th, 2010, 10:07 AM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
Did you go to the Solihull Society meeting at the brew pub in Westminster? Hopefully when you got home you remembered that peeing on things makes them rust; not the other way around!
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old April 14th, 2010, 09:55 PM
My rust and grease removing "Jeffrey Dahmer" bucket solution goes like this:
for each two gallons of water add one can Red Devil lye. Add the lye to the water and not the other way! adding tsp helps the degreasing action.
Use an old battery charger to provide a low charge. I use one that has a 2 amp setting. Now don't clip the charger right to your parts. Use some old jumper cables and let them hang over the edge of your container. The fizzing action can corrode the connections, so you want to keep them dry. Thus the "extension cord". Connect the positive lead to the part(s) and the negative to a sacrificial hunk of steel that is also submerged in the solution. Place the parts in the solution and the sacrificial anode and apply power. You will soon see fizzing and bubbling. This is converting the rust back to iron and the caustic lye is stripping paint and grease. Check every hour or so or leave overnight. The reaction tends to be stronger on the side toward the anode, so it may be necessary to shift things every once in a while.
This is all best done outdoors. Warmer temps increase effectiveness.
Not a speedy method, but outcome is outstanding.
Parts must be submerged, so container size is important as well as firmness of connections. I have actually bolted wires to parts to be sure the connections stayed tight. The more you use this method, the more proficient you will become.
D-90 Restoration / Rust Removal Flagg Defender Technical Discussions 20 March 14th, 2012 10:11 PM
Rust Management loykd Defender Technical Discussions 44 February 5th, 2010 11:00 PM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
» Defender Registry
Tessa #2213
Holiday
DD
Howski
Add your Defender
