Rust Questions - Defender Source
Old April 5th, 2009, 01:11 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Rust Questions
Hi everyone.
I saw a d-90 from FL I'm thinking about buying. It had a rusted rear bumper and the cross member was in bad shape where it attached to the frame. Looked like a little rust on the frame only where the back bumper/CM is attached. The rest of the frame and 90 is very rust free. My question is can the cross member be removed and the frame where it connects to be repaired. If so what is a good ballpark. Can you ever repair a section of the frame or do you need to replace it.
I will post some pictures later.
Any help????
Old April 5th, 2009, 02:35 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yes, you can replace just the rear cross-member. It costs about $400 from what I remember. If you decide to do this, I have a brand new "fixing kit" which is all the brackets you need to weld the new one to the frame. I'll sell it cheap!
Old April 5th, 2009, 02:42 PM
Campbell's Avatar
Campbell
Rich Campbell
Thanks, I will let you know.
Old April 5th, 2009, 04:35 PM
Check your PMs. Feel free to post detailed pics of the frame on image shack or similar (the size limit here makes it tough to tell sometimes). Also post some pics of the floorboard, top of the bulkead and other rust prone areas.
Old April 5th, 2009, 05:16 PM
madcowdungbeetle
Carter
I'll be doing a cross member replacement after the Uwharrie Safari. So I can try to document it and post up some pointers when I do get to it.
Old April 5th, 2009, 05:28 PM
cgalpin has a linked a nice write up with pictures of the procedure on Janey the 110.
Ron
Rust Management loykd Defender Technical Discussions 44 February 5th, 2010 11:00 PM
New to group and I have some questions. wea Defender Technical Discussions 19 August 2nd, 2004 02:35 PM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
