Rust Question / Purchase Advise - Defender Source
Old May 21st, 2016, 04:52 PM
sireland12001
Shane
Hello! I am in the process of purchasing my first Defender and have located a possible vehicle. The car is a '94 D90 ST and looks fantastic inside and out...until I received pics of the undercarriage. I have only received 2 pics of the undercarriage and have requested additional pics. My instinct is to pass on this Defender as a result of the amount of rust in the pics, but I was hoping for some additional input from those of you with more experience/perspective than I have. Any help or advice would be appreciated! Thanks in advance for your help!!
Name:	Rover Rust #1.jpg
ID:	149992   Click image for larger version
Name:	Rover Rust #2.jpg
Old May 21st, 2016, 05:00 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Most of that appears to be surface rust from what I can tell. A day under there with a wire wheel and a can of aerosol epoxy chassis paint would qualify as a restoration in some places. I'd ask for more pics of the frame itself.
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
Old May 21st, 2016, 05:02 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Shane, read the ECR buying guide.
The pictures you showed dont always tell the whole story.
Rusty axle housings arent necessarily the worst thing...
https://eastcoastrover.smugmug.com/C...-guide-images/
Rent my
Old May 21st, 2016, 05:06 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
A new chassis is $$$ so definitely check it out. Also look at the footwells & rear crossmember.
Is it priced fairly?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old May 21st, 2016, 05:07 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
In my experience if the axles are bad, the frame is normally worse. I would be requesting photos of the rear crossmember and frame-side suspension mounts, particularly the rear upper link. Those are likely going to be your problem areas, as well as around the transmission crossmember. Good news is, it looks like they have a number of trucks to choose from!
-Ash
Geared Restoration Co.
352-572-3236
Old May 21st, 2016, 05:09 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
As Scott said, that does not look too menacing. Have a look at the outriggers, the rear crossmember, and the frame rails themselves. A frame swap can be done, but make sure that is priced in. If in doubt, have a local land rover shop take a look. Good luck.
Angus
Old May 21st, 2016, 05:13 PM
sireland12001
Shane
Awesome advice. Thank you all! Great buyers guide...Will do!!
------ Follow up post added May 21st, 2016 05:16 PM ------
Thanks, Paul. 100K miles and they are asking 49K w/ some wiggle room. Black and lots of options.
Old May 21st, 2016, 06:01 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by sireland12001 View Post
Awesome advice. Thank you all! Great buyers guide...Will do!! ------ Follow up post added May 21st, 2016 05:16 PM ------ Thanks, Paul. 100K miles and they are asking 49K w/ some wiggle room. Black and lots of options.
That is WAY too much $. Do yourself a favor and hold off for a rust free truck from AZ, CO, WY, etc.
Keith, what are you trying to pawn off on this guy? ;-)
Old May 21st, 2016, 06:07 PM
Naplm00
Matthew
Yea coming from someone with a rusty truck, that is waaaaay overpriced. That kind of rust is systemic, it's everywhere and the only cure is a full rebuild
Old May 21st, 2016, 06:10 PM
McFly
Marty
84 Delorean
From your pics that looks like Copley.
I presume this one?
http://www.copleymotorcars.com/?show...convertible-13
Old May 21st, 2016, 06:16 PM
sireland12001
Shane
Yep, that's the one! I am super thankful for the advice. Sounds like a clear "pass" on this one.
1994 D90 purchase question TexasD-90 Misc. Chit-Chat 8 October 15th, 2009 06:58 PM
Need Advise about a D90 Purchase therozfather Defender Technical Discussions 21 May 20th, 2009 12:01 PM
To rust, or not to rust ? RBees Misc. Chit-Chat 10 May 8th, 2008 10:40 AM
