Rust Problems - Defender Source
Old October 15th, 2003, 12:32 AM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Unhappy Rust Problems
I heard someone mention something about a LR rust warranty? Do you guys know anything about it? How long is the warranty good for? It seems like the Defender's body tends to rust inside the doors at the bottom and at the hinges? What can I do to protect my vehicle and repair damage that has already been done?
Thanks-
Old October 15th, 2003, 07:41 AM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
A 95 D90 would be out of warranty. I have a 97, and only had 1 month left on my warranty. Sorry.
chris
Old October 15th, 2003, 09:01 AM
Por-15 is a good rust protection. Other then that I hear waxoil is good also.
Old October 15th, 2003, 12:23 PM
What is good to use to stop rust that has started. I have a little rust on the bottom corners of my front doors.
Old October 15th, 2003, 12:35 PM
okay so took a glance at the POR 15 site. Has anyone used this stuff in thier trucks? or the waxoyl? my main intention is to stop what has already started???
Old October 15th, 2003, 01:42 PM
c2sox's Avatar
c2sox
Al Cruz
93 110 #428 and 01 Disco SD7
Question
Any heard of this stuff?
http://www.chemcoint.com/Chemco/rustfix.htm
Old October 15th, 2003, 03:52 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I used the Por 15 on the frame of my 78 FJ40 a few years back and it was awesome. You just scrape off the loose rust, paint on the stuff that bonds to the remaining rust then there is this black stuff that coats and seals the rust. If it is going to be exposed to the sun you have to overspray with paint or else the black coating turns gray.
problems
Rust in the door handles??? adibitar Defender Technical Discussions 4 October 10th, 2004 10:01 AM
Rust Question Rob Defender Technical Discussions 0 August 29th, 2004 01:40 PM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
