Rust on door bottoms - Defender Source
Old May 28th, 2014, 02:25 PM
ssi19's Avatar
ssi19
scott
1995/D90
Have a little rust building on door bottoms. Is there an "easy" way to deal with this and stop the rust from spreading? Or do I need to go "all in" and cut out the rust / add fresh metal?
Old May 28th, 2014, 02:32 PM
Throw out the door seal that is riveted on. Treat and paint the outside, spray the inside with waxoyl clear and it should last a good long while.
Old May 28th, 2014, 09:00 PM
ssi19's Avatar
ssi19
scott
1995/D90
Thanks. Do you need to sand off all the rust before adding waxoyl? Just afraid inside rust will be hard to get to.
Old May 28th, 2014, 09:02 PM
Remove loose rust. Paint with phosphoric acid. Then Waxoyl.
Old May 28th, 2014, 09:12 PM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
I've had great results using Devcon epoxy on ours. Take a small grinder and remove all the flaky rust...Then treat with a rust stabilizer like POR15. Mix the Devcon and apply to the areas, but don't go too crazy since the stuff is super tough and a real pain to sand! Then paint. I bought a little hobby airbrush for this and had a quart of paint mixed - works awesome!! I'll see if I can find some photos of the work...
Old May 28th, 2014, 09:55 PM
Wire brush/ chisel ospho clear waxoyl has done me right for 7 years
Old May 28th, 2014, 09:59 PM
Phosphoric Acid (aka Kleen Strip Prep and Etch) is $15/gallon at Home Depot and can remove that rust to bare metal in less than 48 hours as long as it is completely immersed. It will also dissolve all rust on the inside of the door frame. It does not dissolve steel. I used it on almost everything rusted on my truck to great effectiveness.
It will lightly etch bare aluminum. Not sure what effect it has on the paint, however.
Old May 30th, 2014, 11:12 AM
ssi19's Avatar
ssi19
scott
1995/D90
Thx all
Old May 30th, 2014, 12:28 PM
UTRPh's Avatar
UTRPh
Danny V
94 D90 #1260
Clear Waxoyl
Same situation on just one of my doors. Where do I get Clear Waxoyl?
Anything worth doing is worth getting carried away with(ancient druid saying)
To rust, or not to rust ? RBees Misc. Chit-Chat 10 May 8th, 2008 10:40 AM
D90 ST door bottoms theshield Wanted 6 April 22nd, 2008 11:03 PM
94 door bottoms VS 95-97 Doors? theshield Defender Technical Discussions 12 April 18th, 2008 03:13 PM
D90 Soft top door bottoms only Richard Dekkard Wanted 0 February 3rd, 2004 07:34 PM
