Rust Management - Page 3 - Defender Source
Old August 28th, 2007, 08:00 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
http://www.geocities.com/wallaces_21/waxoyl.html
http://www.mgexperience.net/phorum/read.php?1,22473
http://gerry.vanagon.com/cgi-bin/wa....302c&L=vanagon <- This is the one I will follow as it goes into discussing different formulas.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old February 5th, 2010, 05:57 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Rust on inside of rear cross member
I have some rust on the inside of the rear crossmember. In the corner where it meets the frame rail. I'm not sure I can completely remove this by hand because it is hard to access. I have Waxoyl and the rest of the frame is Waxoyled. Is it bad if can't remove all the rust completely before I Waxoyl it? Is it better if I spray it with Rust cap of some sort?
ID:	24941   Click image for larger version
Old February 5th, 2010, 07:23 PM
Frank84
Frank Battersby
95 D90
I'd make sure all that flaky/bubbly rust is gone before applying waxoyl, POR 15, etc. It will be tough to get in there but spend some time on it and you'll get there. Even just using a flat head screw driver to scrape off will help a lot. Then go with some coarse sand paper or something. Spending a little time now will save a lot of time later.
'95 Soft Top
'89 Classic Tdi
Old February 5th, 2010, 08:08 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
In short, yes. The waxoyl will just hide the rust as it continues to eat away the metal. You need remove it. Might be worth finding a local mobile sandblaster and have them blast the frame.
Old February 5th, 2010, 11:00 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
What about the inside of the rear crossmember?
It's hollow and open on the sides, right?
rust on SW top overlap kolvedic Defender Technical Discussions 0 December 5th, 2005 01:51 PM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
Rust Problems boshea Defender Technical Discussions 6 October 15th, 2003 03:52 PM
