Rust in the door handles??? - Defender Source
Old October 9th, 2004, 09:51 AM
adibitar's Avatar
adibitar
Adi Bitar
2001/ TD5 90 Defender
Exclamation Rust in the door handles???
I have a D90 td5 soft top NAS body specs. Where the door handles are there is rust building up on the inside. Is this normal, if not what should I do now it is only surface rust. I think from water sitting there after being washed or after rainfall.... any suggestions would be great thanks.
Old October 9th, 2004, 10:36 PM
Yep, it is normal, how new is your 90, is it still under warenty?
Old October 10th, 2004, 07:26 AM
adibitar's Avatar
adibitar
Adi Bitar
Nope my warranty finished. It has 70,000km on it 2001 model. There isn't a way I can get rid of the rust?
Old October 10th, 2004, 09:59 AM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
All LRs (at least in the US) come with a 6 year, 100K mile corrosion warranty. This is totally independent of the bumper-to-bumper warranty. Check with your dealer, you might still have that and can bring it in for free.
Goodluck!
Glenn
Old October 10th, 2004, 10:01 AM
adibitar's Avatar
adibitar
Adi Bitar
ok thanks for the info will check tomorrow.
door
Rust Management loykd Defender Technical Discussions 44 February 5th, 2010 11:00 PM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
Rust Problems boshea Defender Technical Discussions 6 October 15th, 2003 03:52 PM
