Rust in footwell? - Defender Source
Old January 31st, 2008, 10:29 AM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Rust in footwell?
What is the guestimate on pricing to fix rust in a footwell?
This is for a friend and his rust seems to go all the way through the floor.
Josh
Old January 31st, 2008, 12:26 PM
61rover's Avatar
61rover
John Crouse
Footwell Rust
These guys make really nice repair panels. The sell them on ebay.co.uk as well.
http://www.yrm-metal-solutions.co.uk/
Old January 31st, 2008, 12:43 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Hmm, is that website not working for anyone else? It redirects to something else which doesnt load for me..
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old January 31st, 2008, 01:03 PM
themaxx's Avatar
themaxx
Ade
94 ST
It didn't redirect, but it doesn't load.
Old January 31st, 2008, 01:26 PM
rmuller
Ryan
Redirects to http://www.chrisncarly.plus.com/ in a frame, so the address bar doesn't show it, but that's the page it's trying to load.
Ok, I figured it out!
Go to http://www.yrm-metal-solutions.com/page2.htm .. and you can browse around the site.
Now the question is.. LHD driver's side floor panel .. is that 'near side' or 'off side' .. I need a Brit->American translator I guess..
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old January 31st, 2008, 03:02 PM
It depends on how bad it is. Usually they rust the worst on the lip under the floor.
Old January 31st, 2008, 04:25 PM
Quimbola's Avatar
Quimbola
Josh
So, let's say it is very bad.
How much to have a professional to fix it?
Old January 31st, 2008, 04:28 PM
rmuller
Ryan
I'd buy the panels from YRM.. bring it to a shop to have them cut out the old one, weld the new one, and if you want, paint it to match the truck.. I don't think the cut & weld will take more than an hour, so it's basically up to the shop as to what their rate is..
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Its just so impossible to say. Could be cheap, could be wicked.
Old January 31st, 2008, 04:38 PM
Depends on how much you have to pull to weld in the new one.
If it were me, I would clean up the rust and weld a couple small patches and save for a new bulkhead.
Old January 31st, 2008, 04:40 PM
rmuller
Ryan
Ron -- Think a patch is better than the full new floorboard from YRM? I have a spot about the size of a fist near the crease.. need to address it soon..
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old January 31st, 2008, 04:42 PM
You can also do wonders with a good cleanup, some fiberglass cloth, and POR15. My bulkhead had minor holes at the bottom, and thats how I fixed them.
The pic shows the area masked for painting, but the rust wasnt very extensive, but I took off a lot of paint to ensure I exposed the whole area.
Name:	Floor Rust Spots.jpg
Old January 31st, 2008, 04:54 PM
If you cut all the rust out and patch it and stablize the rust, you can always do the full repair later or decide to get a whole new bulkhead (the tops of the bulkheads also rust out).
I have seen very nice and very bad patches. Also, the repair panels are of varying quality. Most do not have the reinforcing plates or are otherwise inferior or incorrect.
Old January 31st, 2008, 07:10 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
The problem with just welding it in quickly is that it is hard to clean up the other side of the bulkhead, and you are likely to set the paint/grease/road-grime on fire with the welder. Even more dangerous is the fact that the fuel feed & return both run directly under that spot on the passenger side (on a 110 at least).
Old January 31st, 2008, 07:21 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
To do a good job, you probably need to pull the bulkhead. There are stiffeners on the engine side - one runs horizontally and three run vertically and these need to be inspected and sorted also. Job is not hard, but doing it correctly will take some time. You will be glad you did it correctly
Old February 1st, 2008, 06:50 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
that's so very unrealistic.
Matt Browne
Old February 1st, 2008, 08:43 AM
Seriously. I can recall a few LR's that looked like the welding was done in an hour. Looked like the new metal was glued on with rusty mucous.
Old February 1st, 2008, 08:46 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Roofing tin, bathroom silicone and self drilling screws is what I usually see. I think that can be done in under an hour.
Email:
Old February 1st, 2008, 09:06 AM
Over the years I have notced that every yahoo has his own favorite "miracle material" that can be used in place of welding.
Bondo, Fiberglass, everything that Mike listed. Not to mention the stuff people use for soundproofing. I worked on an 88" that had 1/2" cork bulletin board material glued to it with black mastic. It had degraded and was like 1/2" of chunky black tar. Threw away alot of panels just to save the guy the shop time of me cleaning that up. My 109 roof came with fiberglass insulation glued to the roofsides. Useless.
footwell
Rust Management loykd Defender Technical Discussions 44 February 5th, 2010 11:00 PM
Rust Question Rob Defender Technical Discussions 0 August 29th, 2004 01:40 PM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
