Running Warm to Hot - Page 6 - Defender Source
Old October 26th, 2012, 07:15 AM
Originally Posted by hunterjah
I feel like Tom Hanks in Money Pit......."two weeks"
Get used to it ...
Get a cap today and try it ... They are cheap.
Old October 26th, 2012, 10:54 AM
Originally Posted by bjf View Post
My shop quoted me 1800 with a valve job.
About right.
Old October 26th, 2012, 06:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
This is my 4 core that was pulled. I'm no expert but it looks like something is wrong with it.
Old October 26th, 2012, 06:46 PM
What the hell? How old is it?
Old October 26th, 2012, 06:53 PM
bjf's Avatar
bjf
barry f
94 ST #395
It's only a year old. The good thing is the guy who owns the shop is very cool and said it has a 2 year warranty. The new genuine one is going in now and I will have this one redone. As for the genuine one, I watched them pull it from a genuine box and I have to say it looks like poop. I am sure it will be fine but it looks like it was painted with some ones balls.
Old October 26th, 2012, 06:58 PM
I can take a dump in a box and mark it genuine if you like. I've got the time. But all you've got is a genuine piece of crap.
Old October 26th, 2012, 07:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
Some people swear by genuine. I was just surprised at how crappy this one looked cosmetically. You would think there would be some pride in work in the uk.
Old October 26th, 2012, 07:07 PM
I'm sorry...have you actually seen a Land Rover in person?
Old October 26th, 2012, 07:13 PM
bjf's Avatar
bjf
barry f
94 ST #395
Clearly sarcasm is lost on you.
Old October 26th, 2012, 07:15 PM
You're dry delivery lost me .
Old October 26th, 2012, 08:12 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I would love for someone to tell me where we can get a good quality, aluminum radiator that will work for a stock application.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old October 26th, 2012, 08:17 PM
milroy
Mike/Milliken
OK,
So my RRC has been giving me hell.
I have mad pressure in the system. Ive blown two coolant resevors.
When the truck is sitting and we warm it up, there does not seem to be much if any pressure building (runs fine with the cap off).
The thermostat seems to be opening as there is plenty of flow on the top hose.
The water pump is not leaking and sounds ok.
We did a co2 test and came up with nothing.
The bottom hose does not seem to be getting "flattened".
Runs downhill fine and sitting its fine, but when I try and drive it uphill, all hell breaks loose.
Any ideas?
I live in Maui, so parts are a challenge to say the least.
mike
Old October 26th, 2012, 09:05 PM
Does yours have 3 rows of head bolts or 2?
Later heads had the extra row deleted because it acted like a pivot and caused head gasket leaks ...
Old October 27th, 2012, 12:26 AM
milroy
Mike/Milliken
2..
Should I get them cranked down?
Old October 27th, 2012, 02:37 AM
milroy
Mike/Milliken
ps. I used to own a D. 413/500
Im just tweaking out. I don't know weather to get a radiator or if it is a head gasket issue.
Obviously, both costing a shitload of $$.
I plan to drive it uphill tomorrow morning and see what happens.
I've got the resivor cap only loosly on and I unplugged my AC pump, so the fans are running in front of the radiator (that seemed to help).
While sitting, the temps are Max 195 at the top of the radiator and block and about 160 below the radiator.
I really hope its not the head gasket, cause I love this truck
Old October 27th, 2012, 08:24 AM
You new the cap on to pressurize the system ... Its more efficient at cooling when under the correct pressure.
Borrow a pressure tester from autozone and check the system pressurizes without leaking. Some of the fill plugs can leak when running an cause water loss.
You could change your own head gaskets. It's a 2 day job for an amateur mechanic.
Get your radiator cleaned out by a radiator shop first.
Old October 27th, 2012, 02:31 PM
milroy
Mike/Milliken
Ok. That's the plan. Thanks.
I drove it about 10miles this morning. Everything was ok until the last 2 miles uphill. When I arrived, coolant / steam were poaring out the seal in the resivor tank. WTrover!?
Old October 27th, 2012, 04:41 PM
Could be the cap I opening early I you are lucky. Try anew cap.
Old October 27th, 2012, 05:06 PM
milroy
Mike/Milliken
You mean opening late? I would imagine it should spill pressure before it blows out the tank like its done twice now? I'll try a new cap. I've been putting in on loosely so it doesn't blow out.
Old October 27th, 2012, 06:01 PM
milroy
Mike/Milliken
ERrrr.
Thanks for the help here leastonce I appreciate it.
10 Mile flat and downhill trip after work and nothing. No coolant loss, no pressure build up at all.
????? Mahalos
Running Hot with a/c on Campbell Defender Technical Discussions 44 September 2nd, 2011 06:22 PM
Slow driving = Hot running Burke Defender Technical Discussions 15 July 24th, 2007 09:43 AM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Running like Sh*t...PLEASE HELP! roverboy Defender Technical Discussions 4 December 5th, 2003 12:49 AM
