Running Warm to Hot - Page 5 - Defender Source
Old October 23rd, 2012, 08:05 AM
Id save it, im sure you can sell it here. I kept mine will likely have it re-cored.
Old October 23rd, 2012, 11:28 AM
Keep it until the issues is resolved.
-Jeff
Yes, if the new rad does not fix it then the 4 core is fine.
Old October 23rd, 2012, 11:42 AM
bjf's Avatar
bjf
barry f
94 ST #395
Well not like I am going back to it. I will keep it since it has 6000 miles on it and someone with ac I'm sure would be fine with it.
Old October 24th, 2012, 02:31 PM
red&yellowrovers's Avatar
red&yellowrovers
Joe Still
95 D90 NAS 3.9l ST AA Yellow #2719
Please close the loop by reporting what if anything fixed it. js
Old October 24th, 2012, 02:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
Still in the shop. Genuine rad going in today.
Old October 24th, 2012, 03:29 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by bjf
The extra core with no aux fan since I don't have ac makes it hard for air to go thru
Seems hard to believe imo,
- Charles Eames
Old October 24th, 2012, 04:30 PM
Doesn't sound right. My money is on head gaskets and this is just the start of the longest overheat thread ever.
Old October 24th, 2012, 04:44 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have gone thru most of the threads on radiators on here and some on head gaskets and I don't think I have a head gasket issue. There is not one thing that points to that. Truck never overheats, just gets warm on long climbs. When I got the radiator I thought 4 core would be better but when you take into account that the radiator itself isn't larger and all you are doing is making the cores smaller it seems to make more sense. Now if I got a high flow water pump it would have compensated for moving the water through the smaller cores.
My shop didn't really know what to do. They also work on Mark's truck and our trucks are set up exactly the same except he has a original radiator.
A guy who sets up racing BMWs was in the shop and was looking at my car and he brought up the issue with four core radiators and how he sees the issue in race cars all the time. Remember I only have this problem when I am sitting on a hill. With gravity and the four core the water pump isn't moving fast enough. To me it makes sense but until the truck comes back and I can test it who knows. I know the new t stat fixed half the issue.
Old October 24th, 2012, 05:31 PM
I would agree that the limited flow caused by a 4 core doesn't seem plausible, but explain why you think its head gaskets. I dont understand that.
-Jeff
Because its generating excess heat that the system can't cool. The heat has to come from somewhere. A tiny head gasket leak could inject that heat ...
Everyone else I assuming that the problem is inadequate cooling. I'm suggesting excess heat. And there is a difference.
Old October 24th, 2012, 09:44 PM
I could detect neither on mine ... But when I took the head off I found leakage between a cylinder and waterway.
Old October 24th, 2012, 10:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
What were your symptoms?
Old October 25th, 2012, 01:28 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Exactly what happened to me. Same symptoms as Barry, too.
Old October 25th, 2012, 07:48 AM
Started as occasional over heating ...then became loss of cooling water. I could never detect gas in the water.
Old October 25th, 2012, 03:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
Nothing is easy. Of course my oil lines won't work with the new radiator. Fixed vs not fixed fittings. Need to see if Eric has adapters. My oil lines are Eric's first design before they became red and blue.
------ Follow up post added October 25th, 2012 12:07 PM ------
Except I have never lost coolant and I don't over heat. I run hot sitting on an angle. After replacing the tstat I don't run hot climbing.
Old October 25th, 2012, 06:12 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
Past: '97 D90 LE #135
Did you ever have coolant leak from the coolant reservoir overflow tube (in the fender well)? I have had a similar symptoms to what you're saying, except I have on two separate occasions had a pretty significant coolant leak from this overflow tube when my truck has been running for a while and I put it in park/shut it down. I've never noticed it while in motion and have had my wife drive behind to see if any fluids splattered on her car. Same situation though, shop can't find any issue. I've replaced water pump, no head gasket replacement and no radiator replacement as far as I know.
Current Stable:
2016 BMW M3 (Mineral Grey)
2013 Ford Raptor (Tuxedo Black)
Previous Rovers:
1997 LR D90 LE - #135
1997 LR D90 ST - #1185 (BRG)
2000 LR Discovery SII (Oxford Blue)
2008 LR LR3 HSE (Alaska White)
2012 LR LR4 Lux (Fuji White)
Old October 25th, 2012, 06:24 PM
bjf's Avatar
bjf
barry f
94 ST #395
Aren't you loosing coolant? Sounds like your system is over pressurized.
Old October 25th, 2012, 06:28 PM
You either have a faulty radiator cap or have a head gasket leak.
Old October 25th, 2012, 10:52 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
Yes, I'm losing coolant, it's not quite like a gusher, but I'm certainly losing fluid.
------ Follow up post added October 25th, 2012 09:55 PM ------
What's a fair price for parts/labor to replace a head gasket?
Current Stable:
Previous Rovers:
Old October 25th, 2012, 11:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
My shop quoted me 1800 with a valve job.
Old October 25th, 2012, 11:31 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
I feel like Tom Hanks in Money Pit......."two weeks"
Current Stable:
Previous Rovers:
Running Hot with a/c on Campbell Defender Technical Discussions 44 September 2nd, 2011 06:22 PM
Slow driving = Hot running Burke Defender Technical Discussions 15 July 24th, 2007 09:43 AM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Running like Sh*t...PLEASE HELP! roverboy Defender Technical Discussions 4 December 5th, 2003 12:49 AM
