Running Warm to Hot - Page 4 - Defender Source
Old October 18th, 2012, 04:20 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I would and if it does not budge save the old one for another day. It is also very likely the viscous fan. I'd do both together if there is any play in fan movement.
Old October 18th, 2012, 04:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Fan I did last week.
Horsey
No one has given a clear answer. Chris thinks its the gasket. Ron and Jeff don't not does my shop or a dealer tech who stoped at theshop. Other than t stat it isn't clear what is wrong.
Stick to what you do best. Go tell the guy selling the black truck how nice it is.
Old October 18th, 2012, 05:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
So radiator?
Old October 18th, 2012, 05:51 PM
Originally Posted by bjf View Post
So radiator?
Certainly possible.
Old October 18th, 2012, 06:38 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by evilfij
Certainly possible.
So basically back to square one
Old October 18th, 2012, 07:12 PM
budzny
Real4X4
NAS 97 ST/NAS 93 110/62
Birthday Committee Team
X2!!!
Originally Posted by evilfij View Post
Certainly possible.
Old October 18th, 2012, 08:42 PM
Rover gauge?
Start with google. Charles made up some cables. Would be willing to loan you mine.
Old October 18th, 2012, 09:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will google it. Truck is back at the shop.
Old October 18th, 2012, 10:53 PM
You can have it flow tested.
Old October 18th, 2012, 10:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah will see this weekend. The shop is going to take it to the hill I run hot on. I assume they will bring their temp gun etc.
Old October 19th, 2012, 09:07 PM
jhhorse
joe heins
1995 defender 90
Dunno if you checked this, but if the weep hole on the tstat is not at 12 oclock, or if there is no weep hole, it will let the temp creep up in certain conditions, won't let the air out of the block.
I went through a couple of fan clutches before I found one out of the box that worked properly.
Stock temp gage= no idea what the temp is, definitely use an IR thermometer, a good one, check at input and output of the radiator, etc, will help you get an idea what's going on. Temp drop from in to out on the rad should at least be 30 degrees, I think?
Joe
Old October 19th, 2012, 11:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
Actually my original fan clutch worked fine but I replaced it anyway. The shop said they would let me know this weekend what they find.
Old October 19th, 2012, 11:11 PM
jhhorse
joe heins
1995 defender 90
Should be interesting what they find, my experience is the cooling system in any car is more sensative to the fan and the radiator efficiency that anything else.
Old October 22nd, 2012, 03:33 PM
bjf's Avatar
bjf
barry f
94 ST #395
So my shop claims that the four core radiator is the issue. The extra core with no aux fan since I don't have ac makes it hard for air to go thru it and when I idle on hills etc it will run warm. They think i should get a stock three core radiator and the problem will be solved.
I would replace it with new genuine and see if it fixes it. Certainly plausible.
Old October 22nd, 2012, 04:45 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Totally agree. The stock cooling system on these trucks is fine if all components are working properly.
I really don't understand why people saw holes in their bonnets and buy these giant NASCAR aluminum radiators.
Old October 22nd, 2012, 05:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
Well I wasn't trying to do anything fancy. I know people change fan clutches and fans for range rover crap but I wasn't looking to do anything nuts. I just thought when you recore you normally went to a 4 core. I thought the extra core would help not hurt. Spend and learn is my motto.
Old October 22nd, 2012, 05:18 PM
Buy genuine [or known OEM] is mine ....
Rather pay more once than do it twice.
Old October 22nd, 2012, 05:35 PM
bjf's Avatar
bjf
barry f
94 ST #395
I typically always buy genuine. It doesn't always mean it is better though. I had three steering lines leak recently that were all genuine. I finally gave up and had a hydraulic shop replace the rubber line on the metal pipe. No leaks since.
Old October 22nd, 2012, 09:53 PM
bjf's Avatar
bjf
barry f
94 ST #395
Doing radiator tomorrow. Any value in the 4 core one or should I toss in the trash?
Anyone want it?
Running Hot with a/c on Campbell Defender Technical Discussions 44 September 2nd, 2011 06:22 PM
Slow driving = Hot running Burke Defender Technical Discussions 15 July 24th, 2007 09:43 AM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Running like Sh*t...PLEASE HELP! roverboy Defender Technical Discussions 4 December 5th, 2003 12:49 AM
